so hows everyone for a fund raiser, we have about a week to gather a few items, can be anything i think
i'll put together raffle tickets if you want (my gf and i are planning to go out tonight, she has to get ready, so it will give me plenty of time :))
i also have a turbo timer that might be up for winnings :(
so thats my 2 donations, anyone else? i think its a good idea coz i mean $2 - $5 per envelope of about 5 raffle tickets to win things that are donated its all good :( please reply soon
https://www.sau.com.au/forums/topic/18628-mas-dyno-bbq-fundraiser/
  • Replies 181
i wont be dynoing my gfs car seeing as it was dynoed there like a week ago so theres no point... will be up for the BBQ... dont really have anything to offer for the raffle tho... might think of something.
You dont have to be getting your car dynoed to come.
You can just come to watch... and eat sausages. Mpre the merrier. And it looks like there will be a heap of people there!
We are doing this as a fund raiser so doesn't matter if your not gonna go the dyno... more on the dyno the better...
I have a leather Nismo gear shifter to throw in for the raffle prize. Is brand new - still packaged (RRP $160). Will ask around from some other stuff...
I'll get some ticket books - I think you can get them from Officeworks et al.
Originally posted by inark
lol apachex
that avatar still freaks me out a little :)
so we gotata be there early aye... i'll try my bestest.
ahhah its alrite man, its only my dog, she aint that scary! she iz really small too, like 50cm in length, not that tall, one of those small yappy dogz heheeh, just for u ill change it though, so everytime u come on and ive posted u wont be freaked out and stuff
umm yeah maybe i missed it, but wat are the costs involved?
and does it matter who goes? coz yer some of my non-sau friends seem interested eheh
proper details would be handy :)
hahaha nah man u dont have to change it... i just remember when u first joined it freaked em out cause i didnt know what it was... :) then i worked it out after like 3 weeks! lol
its at BMT which is 6 something or rather thingy in fairfield... lol sorry but i have the memory of a... thing that... yeah more details please!! :)
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
