If your oil pressure has dropped off, the damage is already done.
Especially @ 7000rpm. IMO the oil pressure isnt that much of a help (over the stocker gauge). As ye, once you've done your dinner... thats it.
I'd disagree, I've heard of cases where people have used oil with the wrong viscosity and had very low oil pressure, you could pick this up with a nice oil gauge and same some wear and tear :)
Horrid? Nope. I think they aren't bad for stock gauges unless you are aiming to impress Paul and Vin when V-tec kicks in yo.
Admittedly I've upgraded to the Nismo gauges but hey, they work.
i think stock guages are pos when it comes to readings, and running more then 1bar its just not of use.
what about oil temp, fuel pess, water temp and exhaust temp???
I'd like to see -
1. Dose/flutter meter
2. KM's to Noble Park Macca's
3. RPM till V-tec kicks in yo
4. $ left till I've payed the car off
and last
5. Number of Bush cops I've noted on the way to Noble Park Macca's
hahhahha kms to maccas watta crack up.
volume of dose would be a good one aswell
Edited by R34NRG
I vote you save the money and spend it on something that actually needs upgrading.
dude, if u wanna pay for that something that "actually needs upgrading" go for it. if not is it okai with you if i buy what i want with my moneY?
Of course, do what you like with your money mate. Go for oil temp/pressure (lets you see if the engine's heart is pumping, and also if it has warmed up so you dont flog a cold engine), Boost needs no explanation. I thinks that all you really need, I just meant 5 guages I think would be overkill.
You already have oil temp and water temp. Let's be realistic, fuel pressure and exhaust temp are just novelties.
Do you actually run more that 1 bar!?
Don't forget you'll need to allow for sensor installation also if you start putting all these crazy gauges. I'm 99.9% there is no sensors for exhaust temp and fuel pressure that you can use.
oh yeh i know what u mean, i opted for 3 in the begining, just replacing the stockers, but im getting the other 2 at a discount, and my mates not using his a pillar...so meh
day to day driving i rarely even make boost, but ive got it set at 16psi (1.2bar???) but i only hit that on the "odd occasion".
thanks for pointing out the sensor thing, i was certain defi would supply em, its just a matter of linking em up.
will have to give this more thought then, thanks
if anyone can confirm if sensors come with the gaudges that be great
Edited by R34NRG
By they way how is your RB30 with GT30 project going? Did it ever come to fruition?
thanks for asking man, it is actually, but nothing has been put into the car yet, still buying parts here and there. should be going in for the transformation when the bottom end is done.
atm im doing a wide body project aswell...so been buusy lol
I'd disagree, I've heard of cases where people have used oil with the wrong viscosity and had very low oil pressure, you could pick this up with a nice oil gauge and same some wear and tear :D
Yeah, in which case
You shouldnt be allowed near your car (if you cant select the right oil) >_<
oil pressure guage is very important. it tells you how things are going. and if something goes wrong mine activates a big red light and a buzzer which means I can shut off straight away and save the motor. also I use it to record a few laps then replay it back in the pits so I can ensure I'm not getting oil surge through the corners.
    • Have a vb in honour of the car comming back
    • It was a great, but typical track day, and some VB was ingested at the night time debrief 🤪
    • And so, to round this out, I couldn't be happier to confirm @MBS206 has decided to buy the car. He drove down from sunny QLD with a trailer last week and it is off to its new home today. I'll let Matt confirm on next steps but I understand broadly that the plan is to leave it pretty much as is, and just get some quality wheel time with a nicely balanced car that is pretty much track ready. There are a few a jobs still to be done first but nothing too major and I think its a very smart buy Dinner last night at the Paragon with a round of VBs (mostly) for Neil
    • Well, 50 pages and the end of a chapter for this car. We took it out for a shakedown at Wakie yesterday, and everything went well. There were a couple of niggles: - Oil cooler fitting leak - tightened, cleaned, stopped leaking - Radiator cap overflow fitting was leaking....Mark called it, the overflow fitting was threaded in and not tight....tightened, tested and held pressure - Small oil leak at the rear of the block, probably the turbo oil feed - too hot to get at it comfortably but probably just needs to be nipped up - leak at the driver's side rear brake line where it meets the hardline. Fitting wasn't loose, so Matt backed it off and back on, no further leaks - there's also a leak somewhere on the top of the fuel tank, maybe that cross over fuel line - that was has been left to fix when its on a hoist Otherwise than those niggles the car went great, turned great and stopped great so it was a very successful day out. I'm always really nervous when a car first hits the track after a long break, especially with a brand new engine as well but it was great. VID-20251011-WA0007.mp4  Big thanks to @The Bogan who dropped by and helped out, @MBS206 and my nephew Lachlan the apprentice.  Neil's wife Mel also surprised the hell out of all of us by dropping by; she's up in Tamworth these days but was travelling to Melbourne so had plausible deniability for turning up at the garage, it was great to see her but also obviously a bit sad all round.
    • Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state.    BOTH SETS ARE IN FANTASTIC CONDITION (REFER TO PHOTOS)    ✅ No broken covers or cracks ✅ Lenses are in flawless condition ✅ All rear mounting lugs intact ✅ Comes complete as pictured ✅ Perfect for restoration, replacement, or upgrade   These lights are ready to go, no surprises just quality OEM parts.   These are definitely one of the better sets we have seen in a while. With minimal wear and tear they will come as you see. Bear in mind they are not brand new they are almost 30 years old now. To find them in this condition isn’t easy they can only be obtained on the second hand market.   Australia Wide Postage Available At Buyers Expense. Silver Set:$850 Grey Set:$850 PM Me for purchase or any other questions  IMG_2166.dng IMG_2165.dng IMG_2172.dng IMG_2173.dng IMG_2174.dng IMG_2179.dng IMG_2180.dng IMG_2260.dng IMG_2258.dng IMG_2259.dng IMG_2261.dng IMG_2266.dng IMG_2273.dng IMG_2274.dng IMG_2276.dng
