  • Replies 148
gees.. that was sooner than I thought..
I was just crunching some numbers and 7.8 million yen = 76,500 odd AUD?? pretty cheap considering..
Also I saw this pic on a cover of a mag at the servo b4.. Is the the american Version?
i dunno bout an onslaught.. america is the land of the most powerful street supras... i think the gtr will have a lil trouble holdin its ground when theres an army of 1000hp+ supras lol
time to scan that head to head run of the JUN 1000hp Supra and the Bugatti Veyron that option mag did a couple of months ago.
oh and the japanese nissan website now allows you to make preorders for the beast. VR38VETT or something like that.
I dont
Give it time and the japs will go over there and beat them (again) in their own backyard :ninja:
No it doesn't, it just says "get on down to your local Nissan High Performance Center to make a preorder". Nissan won't make ordering the GT-R that simple...
http://www.7tune.com/?p=109
we talking about modified supras here, comparing to stock..wait for the modifiers to do the new GTR then you can compare :bunny:
    • Ok I get you. But isn’t the butterfly intake a headache with the +T?  see this is my plan so far but please advise me into the right direction.  Nistune Ecu, 1000cc Bosch injectors, TD05 or TD06 Kinugawa turbo using stock rb25det exhuast manifold, walbro fuel pump unsure of model I think it’s 450/460, spitfire coils and sparks to suit and a R35 MAF sensor and boost sensor.    I was thinking maybe do a cheap eBay plenum $400-500 or try find a stock det neo intake. I think I’d port match it so it’s getting the full capacity but open to advice please.  Thanks
    • The issue now is the 'fuel cut' while driving, and when it happend, it does not stall. This, I did not test the fuel pressure while driving as I cannot with a fuel pressure gauge. I do have Nistune logs, yes. I have also replaced the MAF Sensor.   Also related to the FPG Fuel Hanger – I just realized that I need a Deutsch Crimp Tool to crimp some cables for the FPG Fuel Hanger. Need to purchase additional cables as the kit only included 2, which are for the float. FPG has not responded to my emails so far since purchasing. I thought about taking it to someone and having it done professionally, but I am reluctant since everyone I took it to messed up in some way.
    • There's a good German place in Brisbane if youre up for the drive 😛
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
