  • Replies 369
pretty cool hey... sctv production did an awesome job with the fades etc.
did it run with the interview from weeksie about the lambos hitting each other or did it get cut in time?
savman - i'll post up the tassie date, shouldn't be far.
That wasn't me with an Evo 5 or 6 all over it's bum! I had three people ring and ask me what was holding me up! LOL
Stu, when's the DVD gonna be available (I'm assuming the tv telecast was a cut version?), it was a good production! :(
FYI, 7HD went crazy and dropped out for a minute or so when Mozz's fat guts were on show @ Prologue
Oh yes! LOL, it ran in alllll it's glory. "...... I didn't see the finish line" hahaha
wonder why he wouildn't have slowed when his nav said "Flying finish"??? hahahahaha :(
Yes, HD.
And I agree on the same shots being re-used. I would have thought that with the constant whinges from competitors who don't see their cars that NO footage would have been used twice for "filler".
Marlin - Not sure of actual date yet, but would say mid/end-July.
phunky - your right repeted shots is frustrating, but time is always a problem as the production crew were stretched.
Stu, when's the DVD gonna be available (I'm assuming the tv telecast was a cut version?), it was a good production! :happy:
O that wasnt you holding the Evo up before a break then not sure if i sure your car then.
super slowmo close up, can't complain! The doco was 100x better than last years (which IMO was the worst one ever)
is the dvd doco going to be differnt than the tv one? (like it was a few years ago)
would have liked to see weeks footage from paradice :D . We almost did the same, didn't see the FF or the flashing lights, the stopped cars were a give away though.
just watched the special features proof disc. pretty cool with 3 to 4 shots of each car in the field, plus a heap of incar and profiles from both classic and modern field.
there is also a summary of results and the nightly tv news packages from each day.
further to all that there is also a short profile on the r35 and an interview with driver tony alford, as well as full length incar of the fast harford stage.
will advise a release date shortly.
Whats with the sig Ben...
Have Evo Brembos but not sure ife the PCD of the mount is the same. Also DMS shox although your mates with Fulcrom aren't you.
You drive a "T" like the R34 and it will shake a lot up... And the RB20... you'll love em.
Good luck. PS Also have springs too lots of springs!
TT984
G'day Greggy!
I'm not sure whether Evo Brembos will bolt on? Maybe Brisby the 32 guru could chime in here? I found the car has a near new set of APEXi coil overs in it, which to my suprise actually feel like they'll be pretty good. Last weekend's test day at Winton showed it to have pretty good traction and was really fairly tidy all round. It even rode the curbs fairly well but I'm still interested to see how much travel it's actually using.
I'm really looking forward to getting it out onto a tarmac stage, I think a little 32 could really shake up a few if I can refrain from having too much fun and driving it sideways everywhere :banana:
Rex Broadbent is awefully quick though :thumbsup:
G'day Greggy!
I'm really looking forward to getting it out onto a tarmac stage, I think a little 32 could really shake up a few if I can refrain from having too much fun and driving it sideways everywhere :D
Rex Broadbent is awefully quick though :)
Yeah, end of Day 1 2005 there was one sitting 13th outright. :(
GTS-t is one of the most forgiving, easy to drive fast cars you will ever sit in... I regret letting minego to that useless Rocket - just as the rules came round to suit them even more.
and to rub salt into the wound, he took a snap of us this year with the old girl in the back ground!
Not sure you will run with the RSR in the dry, but you'll hose him in the wet.
Anyhow, I'm all emmotional now...
Winton, what are you doing down there... I thought you were a Queenslander?
TT
984
    • That's probably OK. That's a face to face compression joint between two surfaces with the clamping load provided by those bolts. So.... it's unlikely that the bolts will end up feeling that load in shear, unless the clamping surfaces are not large enough, bolts not got enough tension on them, etc etc to prevent the two faces from moving wrt each other. Which... I would hope the designers have considered, seeing as it's probably one of the most important things the upright has to do apart from resist collapsing in its own right. But yes, it would definitely be worth asking them what their safety factor on that part of the design was. I tend to think that the casting, being a casting, is not necessarily the strongest bit of material in the world. It's about an inch square, and when you think about the loads that are being put into it, you have to wonder what safety factor the Nissan boys (and every other OEM engineer who has designed all the millions of other uprights that look essentially the same) used to account for defective casting, aging, severe impacts on the wheel, etc etc.
    • Those bolts would be orders of magnitude stronger that cast aluminium though.  And its mainly clamping force, not shear they are dealing with?
    • Except all that twisting force that is breaking a cast piece, appears to be going through 4 bolts in the picture Johnny posted of the BryPar one...
    • The smart approach is to use the gearbox loom from the manual car. Makes it a lot easier - just plugs into the switches on the box and plugs into the main loom up near the fusebox. Then you only need to deal with bypassing the inhibit switch. The other approach requires you to use the wiring diagram to identify those wires by colour and location, perhaps even indulging in a little multimeter action to trace them end to end to make sure, and then.... you will have the answers you need. The R34 wiring diagram is available on-line (no, I do not have a link to it myself - I would have to do a search if I wasn't able to go to the copy I have at home).
    • Hi, i’m converted my r34 4dr auto to manual but need help with gearbox wiring. There are bunch of wires no idea which one for speedo drive, neutral, reverse can anyone help me. IMG_6860.mov
