Time choice required.
32 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
  • Replies 219
Do you always speak in the third person, Ed? :D
i was referring to the Haysey mobile, but occasionally 3rd person is good.... makes it interesting...
Abo has been into the Black Label Crack that smokey and i sold him...
lawl
+1 for nasho with smoky in the boot
:D x 1
what does this mean!!!?!!?!?!?! In plus 1 or plus 1.5? or just you!?
man if you don't show up now, you'll be in so much trouble!!!!!
I'll come along.
I know what will get you there: let's make a bet on your attendance?!?!
Don't you wanna finally become an adult, Vic?
ahahaha oki doke! I'll be there. Only to stop Amy sending me abusive emails! LOL
You do realise you can comfortably sleep 4 in Hayseys new boot right???
thats what i plan on doing when i go to bathurst in two weeks for the big race hahahahah
i can fit a whole family in my boot!
:blush: = Me
Prol not plus 1.5 since .5 has been known to :) on occasion and I don't want to ruin everyone's dinner.
Don't think 1 is ready to leave .5 behind yet either :D
Ok we've got roughly 7 bodyguards for each leb at this stage. I've got a stash of AK-47's at my place, could all attendees please collect theirs on the way through Sutherland. Charlies, it's not safe for you two. We will have you picked up in armoured skylines. There will be decoys so get in the 2nd or 5th car ok? These babies do 0-100 in 17 seconds due to the extra weight involved in proper body armour. If everything goes wrong meet at the secret bunker under Kurnell at 0500 hours. Knock 3 times, pause then 9 more times and when asked, "Do monkeys wear bikinis for attention or is it a wider problem?" answer, "My father built the railroad, the kangaroo hops backwards in Spain." The questioners reply should be, "Orange cockatoos eat the moss from St Davids church tower bells." If you don't get this answer the person is obviously an imposter and should be shot immediately. It is possible they just forgot the questioners reply but that will teach them a valuable lesson in rote learning. So valuable you can't even sell it although I imagine that if you could, some people, and let's be honest here, the more well off members of society, would pay what could commonly be called a pretty penny. How a penny can be pretty is anyones guess since they are brown and large, much like my mother.
BWAHAHAHA unfortunately i beleive you peiced that together from gum wrappers, monty python and family guy
Just for the dedication to our members i'm IN! providing SAM916 drives me. I don't very much care for driving
ROFPMSL :blush:
what exactly is a ROFPMSL? are there any ROFPMSL socks?
u just want me for my car....
no worries mate....but ur deso next trip out!!
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
