Hi guys im running an RB26DETT from an R33 in my 32 GTR...
So far if has a trust exhaust sytem from the turbo back trust dump pipes, high flowed cat, pods boost controller and N1 turbos... i have just bought a power fc and hand controller... i've heard the turbos are good for at least 300awkw. my question is this wht sort of injectors do you guys recommmend
im looking at either 550cc, 650cc or the 700cc size.... what would be best im also upgading my fuel pump... Any advise would be great
Mikeymike
https://www.sau.com.au/forums/topic/187118-modifing-my-gtr/
Mikeymike
Things you need to consider:
How many ho do you want?
How many hp will the stock internal engine accept before you start having issues with durability?
Re the injectors: Pick some, doesn't matter. I run 700's & it is fine. Sard are good.
Re the fuel pump: Nismo make a good one.
It is worth replacing he AFM's also. Cams gears as well.
There is a thread on Rb26 engines in the forced induction section. Check that & see what others have done & what results they have got.
https://www.sau.com.au/forums/topic/187118-modifing-my-gtr/#findComment-3378658
Depends on what you want to use the car for!!!
If you want to do regular track days i would look at doinfg and external fuel pump set up with swirl pot and the like. If you are just going to use it on the street i would probably look at an Bosch 044 fuel pump.
With regards to injector i would look at the 650's or 700's as they will supply plenty of fuel if you start do do further upgrades to the GTR.
Z32 AFM are definetlety the go as well.
https://www.sau.com.au/forums/topic/187118-modifing-my-gtr/#findComment-3378803
Mine is very similar in specs, am using what I believe to be 550 injectors and HKS cams = 303.5kw at wheels using 18psi not to over-stress the stock internals. Also I am still using standard dump pipes and AFMs!!
https://www.sau.com.au/forums/topic/187118-modifing-my-gtr/#findComment-3378863
really who tuned it..... im gonna run with the 700cc injectors as they are gonna cost me the same amount of cash as the 550cc's...
as for my cars purpose track/street car so a swirl pot and external pump are what im looking at
https://www.sau.com.au/forums/topic/187118-modifing-my-gtr/#findComment-3378889
Hey Mate, Ive got pretty much the same mods as you are looking at. Car is nearly finished being tuned now, I had some Z32 afm's to go on but when car was being tuned I was told the stock ones are good for approx 340rwkw and mine are not maxing out....but if you fell you want them they are for sale. I opted for the 550cc injectors and a sard fuel pressure regulator due to getting them for a good price but I would recommend going 700cc. Also using a bosch 040 pump and aftermarket cam gears. Most of the tuning has been done and the power figure is around 310rwkw but I will post up the exact results hopefully tomorrow.
Tuned at BOOSTWORX-82990621
Ryan
Edited by ISC-Performance
https://www.sau.com.au/forums/topic/187118-modifing-my-gtr/#findComment-3378973
Was tuned at Southern Hi-Tech Dyno Tune. Could have pushed it further but I decided to keep it sensible and reliable. John keen did the tuning... very good.
https://www.sau.com.au/forums/topic/187118-modifing-my-gtr/#findComment-3378990
If you're after a fuel pump, look here Fuel Pump
you wont find a better pump for twice the price. I'd say you'd want the 044.
This guy will have the pump out to you fast, I only had to wait a day, ie. paid monday night, had it by wednesday lunch time.
https://www.sau.com.au/forums/topic/187118-modifing-my-gtr/#findComment-3378993
Ryan
yeah let me know how it goes... im gonna be picking up some cam gears in the next week or two so hopefully i can get the 044 fitted cam gears done injectors fitted and power fc tuned.... hopefully i can break the magical 300kw mark
https://www.sau.com.au/forums/topic/187118-modifing-my-gtr/#findComment-3379191
    • Hi. Can someone tell me what brakes(and mainly WHERE) can i buy brakes on R34 GTT? I bought some EBC which SHOULD go on my car(i have GT but it has GTT brakes) but it does not fit, Brakes are "too" small(296mm) Are 310mm be good or? I have 17 inch wheel so no "big boys" but for me driving i just need one that fits and i can get here in EU/Czech.
    • Since winter isn't that harsh anymore in Poland, i will definetely drive it 365 days a year 😉. But if the snow hits i will try it for sure and let U know. Only swap i am planning to do is of course R34 GTR front 😍.
    • Hey. Very valuable information about pitwork, I will pay attention when buying any consumable parts 🙏 As for the carpets - I got a handful of information from nengun, from which it appears that indeed the carpets for the driver's side are OEM. They are not able to show me any pictures due to the long chain of different sales entities but after I place the order, as soon as the goods arrive at the nengun warehouse from which they will send the shipment to me they can send me photos and if my purchase differs from OEM I can immediately return it / cancel the purchase. I think I will give it a try 😉. Of course i'll let you know what's what as soon as i get them P.s. I know the topic is not relevant to the thread, but both nengun and amayama have these SICK 😍 trunk room lamps available. Do you know anyone who ordered them? I need to have one in my car
    • I've managed to find this: Nissan_Stagea_AutechVersion260RS (1).pdf
    • I believe @Duncan has given it a crack at Mt Buller before (in actual race conditions)
