  • Replies 812
tell me about it, i sold brakes for $500 and have to spend $3500 to replace them.
haha. you planning on getting rid of it already? or just for the right price ay..
i was looking into doing this as a project but i think i'd get bored from how long it would take with available funds atm.
grrrr it's 2:33am and i've been sitting here pretty much re-reading the whole thread haha!
makes me wana start mine right now. still got a lot of research though!
would you mind if i asked you a few question when i get stuck on mine?
wish me luck at work in 2 hours haha
Purchased a GTR style front bar ages ago, there is a pick of it somwhere earlier in the thread.
Some Vielside side skirts, and a GTR bonett to go on very soon i hope. Also bought a glass bootlid but it does not seem to be much lighter than the metal one. have to weigh it.
can you say 'race spec!'
What front bar are you using.. decent sized oil cooler too!
basically the same car, i cant see it being to much different. Spoke to SK today about a suspension package. You would be amazed on what i learned in 20mins on the phone. want to get the car running in the next few weeks and then sort suspension and then brakes. Might have to sell go-kart.
Can't weit to see this in action.. been waiting for an ls1 powered 32 for ages! So many ls1 s13's now though.
yea i was wondering what suspension you're going to be using seeing that you're using it as an all rounder.
Car has been at panel shop for last week getting fitted up. Had the boot sprayed also. Bonnet pins fitted etc and then a final buff, came up mad. cant believe it is the same car i picked up from Qld 18 months ago. this is the first time the car has had all the panels fitted.
Got the lifters today and should have the heads next week.
Pulling box back out tomorro to play around with release bearing clearance.
Cpmputer arrived during the week. Going to purchase some guages, finish the dash and get the car wired so i can fire it.
A few before and after shots.
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
