i have been in contact with Mu Secret based in Sydney in regards to a few of their items which i thought you guys might be really interested in. they were quiet helpful and were thinking of starting a trader account, but my approadch to them just gave them another reason to see their potential before making a final decision regarding joining the crew as a trader:D Offer is starting as of TODAY Saturday October 6th, and will go on for 2 weeks until October 20th!
if i can get 3 orders for each of the following can get at the prices as listed:
Tial-style Wastegate 44mm, purple coloured- $300rrp, $220 GB
Tial-style blow off valve, includes weld-on flange. colours are chromed, black, red, blue- $125rrp, $100 GB
Wheel nuts, similar style to RAYS, VERY lightweight open ended, can get 1.25 and 1.5 thread, colours are black, red, and blue. $100rrp, $80 GB
HID lights, can get in any heat range between 3000-12000k, available for any car, low beam only $350rrp, $250 INTRODUCTORY PRICE! *edited* spoken to andrew from Mu Secret, this is now an introductory price until end of GB so doesn't matter how many orders i put through to them:D
Goods can be collected from the Mu Secret store located 15mins from Sydney CBD (Concorde/Burwood), otherwise freight can be organised which cost is dependant upon location and weight of goods purchased.
please let me know if you need more pics as ive got some on my camera!
Dom
Edited by bloodsword27
https://www.sau.com.au/forums/topic/188136-hids-wheel-nuts-bovs-and-wastegates/
HID's are now available as we Introductory price before they plan to become official traders! get em while they're hot! pic of the difference on my car during the day of normal bulbs and a 8000k kit...very happy with it :P
1st post updated with some pics!:/ let me know if an help with anything else as well!
sorry guys should have made that more clear. it is with 20 nuts only, open ended, no lock ones
have had a few orders for the locknuts already so they're good to go for that price :(
have had a few orders for the locknuts already so they're good to go for that price :)
Can you get locknuts?
I'm after aluminium rays / buddy club lock nuts in black.
What am I looking at pricewise?
Cheers mate.
Cheers mate.
so ur after the actual locking ones or the normal wheel nuts (hex type)? RAYS short type closed end is $220, long nuts are $280 a set in black, blue and red....can source up the buddy club ones if that's wat u were after....
dude, this has just turned into you taking orders and selling stuff, ie not a group buy. If Mu's secret want to become a trader tell them to contact me and I will happily sort it out for them.
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
