Damn man thats gotta suck for him and you!! Not even sure if we are going in 2 weeks yet!! We are drumming up some sponsorship with a guy that worked for Mclaren F1 and has since retired back here! He's looking at starting up a F3 team, Hopefully for us this come thru, we will see!! Whats JB gonna be doing now?? Has he any plans?? He must own a car himself to race surely!!
G'Day stranger, Not a hell of alot happening over in little old SA, How about over there in the big smoke??
Nah he doesn't own any cars always driven someone elses. At the moment he may be driving the car for the new owner (why wouldn't you want him he's won 5 out of 6 races in it) I'm still heading over as i have other business to do over there and people to see
Good luck with the F3 team, great to see another SA team out there. BRM are changing to F3 next year with Percat driving
Matty that is SEX on wheels, LOVE it!!!
Dan, good to hear about the Evo, loved every minute of the drive home I spose? God I can't wait to have that feeling with my new ride; just have to find one first!
Yes im back evo is absolutely unreal...but needs a tune and has f-con v pro
awesome mate! cant wait to see this car in the flesh.
good luck with the tuning of the f con v though :S
Edited by Sambo33
well ns is total ghey my group buy tint thread gets deleted after some tool say 'oh i thought you couldnt do GB on here'
and i was like well theres a PS3 group buy any ways mine gets deleted PS3 stays i suppose the mods want a cheap ps3 :teehee::rant::yes:
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
