anyone here need there guards rolled? Getting my hand on a guard roller next week to roll chad's and possibly my car. If i do a good job on my car, would anyone been keen to get there guards rolled?
Hey ppl, I haven't been on here in ages... Pretty much my Skyline has been in and out of morpowa with cooling and suspected coil issues.
Making me broke in other words. Cooling is all fixed but ever now and then it will drop the first cyl making it run on 5. Diognostic said something to do with ignition something... Has anyone had this problem?
Morpowa are looking more into it
. So... Anyone had this before?
Thanks SAU ;)
Would that make it do it all the time or now and then? Engine light comes on too...
They seem to think it could be from water and coolant getting in the coil...
It's a big job just to get to them on a non turbo.
if water or coolent is getting in there check for a split hose around the top of the motor. I found one in mine i had to replace it..
I had to take mine out roughly 3 times as i tryed new spark plugs and they didnt work, then i tried wrapping the coils in tape and that didnt work, then i put the splitfires in and that worked. Only takes me roughly 10mins to change the plugs/coils now.
Engine light might mean a loose connection somewhere, or could be the coils. Bad coils will make the car chug every now and then but sometime seem fine.
Engine light comes on whilst still running?
Misfiring really comes down to a few basics. It's either the spark plug itself, the coil, ignition amp, ECU issues, or any of the wiring and connections between the listed components. It's just a matter of working through each item and removing it from the equation until you pin point the problem.
I would start with identify which cylinder it's dropping and then go from there. If the plugs are all fresh and aren't being continually re-fouled then look at swapping the coil over from the cylinder that is dropping out and see if the problem follows - it might take a bit of time if the problem is intermittent (intermittent problems are a PITA).
Make sure you also clean the coils and the area in between the rocker covers and ensure they are all free from moisture. If moisture (from coolant or any other source) keeps appearing after you've cleaned it thoroughly then something is certainly amiss and it's not a coil problem!
I've got 6 factory RB25DET coils in perfect health sitting in my shed that can be used for testing purposes - unfortunately they probably won't help on a R34 RB25DE.
Good luck.
Good luck.
Yeah engine light comes on while it's running like that then goes off when it's back on 6.
The coolant issue was sorted with the new cooling system so I know how it could have got wet.
Morpowa said it's a big job to get to them? Taking off water lines and stuff... Like a 2 hour job.
I think it may be coils as luke said cos that's what it does... Sounds good for a Rex but when ppl see it's a skyline it's embarrasing!
Its not a 2hr job lol u dont need to take the inlet manifold off, just the throttle body and use a whole heap of sockets. If u get splitfires and need a hand yell out and i'll do it.
Mitch, maybe the guy who sold you the car blew the previous rb26, got a cheap half-cut, threw in that rb26 and then sold it to you?
Crazy stuff dude.
nah he went from an rb25det to this rb26dett
will hopefully know whats wrong with it tomorrow, id LOVE to buy an rb26 from an R34 gtr but that wont happen.
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
    • When you pulled it off, there is no signs of blown head gasket? Is it possible you have some other issues going on? Possible cracked blocked? Or do you think it's straight up lifting the head? Did you check what the head was torqued to before pulling it down (To see if possibly they're stretching, or starting to break threads out etc)?
    • Seems like a decent result for a modded JZX110. They are bulky in comparison to the 100 and 90 models (which I'd prefer myself) but they are getting very few and far between here in JP these days. Thanks for the detailed review and the import process into the UK. I also have a car which I'm hoping to export from Japan at some stage so it's good to know if someone from the UK was interested in it. By the way the corrosion underneath is par for the course for cars which were located in/near the mountains or along the Japan sea coastline. They get huge amounts of snow every winter and the sodium chloride is used on the roads. Many cars have some kind of rubber like treatment underneath but they tend to limit it to the wheel arches underbody and fuel tank. Suspension arms and sub-frames will have similar corrosion to your JZX110 which is a common sight. See it all the time and car dealers here generally don't even mention it unless asked.
    • If the sound goes away when you clutch in, the 1.5/2 way diffs are just shit, and you are a normal person. The diff is likely "fine" but driving at anything under 30kmh is a violent horrible experience. It would be exaggerated with solid diff bushings and subframe bushings if you have those.
