yeah. it was pretty rad. and the mad ringies on main north made me moist. mmmm, single peggers.
also, if anyone wants HID's, theres another group buy on the r31 club, run by angry.
theyre pretty farken cheap, but pretty good quality, used em on my celsior, probably gonna grab another kit for the 200.
very good quality, and he can get more than just single H4s too. got my set of H4 Hi/Lo solenoid controlled HIDs during the week, and got them in today
plus i got my lightforce crystal blue clip ons today haha
F*cking YEAH!!! Finally, after 8 years, I'm off the pair gain system! I've been on Dodo Dial-Up for a good few years now and am SICK OF 31.2kbps speeds!!!
So, here we come Internode ADSL2+. Put my application in last night after hanging up on Telstra right after they said "Yes, you are off the pair gain system.... are you interested in signing up with Bigpond? You get fre.."
I hate Telstra. They took that long to take me off that shit. They came up with bullshit like "no free ports" and "we're too busy". I don't give a shit! They make billions!! I even worked for a contracting company for Telstra and I still couldn't get off the system... although, I was close.
No more 300 ping in cs! Lol. And no more downloading updates for programs on my work internet and burning it to CD and taking it home to install as it'd take days to download on my home connection.
And no, I didn't want wireless internet nor ISDN!
Holly mother
that is huge, but then again when your gaming you use quite a lot of data
lol I easily manage to blow my 40Gb per month .... 3Tb of HDDs and I am nearly full so about to buy another couple .... Usenet ftw
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
