Had a wheel alignment and puncture repair done at Adelaide Radial Tyres at Ridgehaven, corner Lower North East road and Hancock Rd. Excellent service, i was a walk in and they did it on the spot for me. $65 for a 4 wheel precision alignment and $25 for a puncture repair, had a screw in my tyre and didnt even know. Big +1 for them!
yeah he was telling me about the Holden Hill shop. They also sponsor a "josh" with a drift car? Also a distributor for Maxxis, 235/45/17 Maxxis Victra i-Pro retail there for $225 fitted and balanced. Wanted a printout of my stats but they haven't hooked the printer up to the new machine yet :D
Yep I got a couple of Maxxis tyres from Daryl last Friday. Always good, and prompt service.
Oh, and it is just North East Road, not Lower - that is a different road entirely.
does any one here have a r33 stock turbo elbow i can borrow or buy i need one to get my car back on the road and to get it tunned and i havent got much time 2 do it in even if i borrow it to get it tunned then my car sits till i get another one lol
yeh, i had the mistake of sending mine away with the turbo that was 'supposed" to be highflowed but didnt happen so now i got the gt30 highflow i need one again and ill b done
borrowed adrians (rad 32's) rb20 stock one hoping it would fit but a tiny bit smaller. thanks again adrian
I have one that I bought on eBay that I was going to use on a T2 turbo, but they are a different size. you can have it for the $40 that I bought it for.
niiice! adelaide radial tire are awesome been deeling with them since i was 16 when they had their old old store near golden grove.. daryl is always a pleasure to deal with. now im dealing with i think its mathew near holden hill. awesome bloke! currantly setting my R up with front and rear camber arms, castor arms, all bushes replaced, hicas lock and semi slicks!
+ 1 for adelaide radial tyre
    • Put a fuel pressure gauge on it. Replace the turbos. Probably completely separate issues.
    • What copper washer do you guys use on the bleeder bolts? The existing one I have I had no idea where to find it in a local store, I did buy some online but that are only 1mm thick whereas my old one is 2mm+ thick and when I put the new washer out and squeeze the top radiator hose I can hear a bit of air but not with the old one. Does this matter? The new one doesn't leak, but the inner diameter is a bit loose whereas the old one threads on the bolt.
    • Howdy all, after being out a few weeks ago on a spirited drive in my GTR I have 2 issues that oddly have appeared at the same time. Whilst accelerating quickly through the gears all of a sudden i’ve lost power at the top of third gear (below redline around 6000rpm) for no obvious reason.    From that point onwards the car has been running rich on idle, won’t really rev under load without a ton of black smoke and the odd backfire, and dying as a pull up to a set of lights unless I keep the revs up around 1500rpm. In addition when shutting down the car that same night (I was 10 minutes from home) I noticed one of the turbos was significantly noisy on wind down when shutting off the engine. After letting the car cool down overnight it starts up fine, although once it gets to temp the revs start to creep up and down, the exhaust is darker than it should be and it also sounds like it’s running rich (fat note) I’ve put a new set of plugs in it - no change, the old plugs all seemed OK with two of them being somewhat richer/fueled up than the other 3 with 1 being borderline. I’ve smoked tested the intake system via the front of the Turbos, found a split vacuum hose going to the factory boost gauge sender, which I have since replaced.  Also found another leak on the gasket coming off the rear turbo outlet, have also replaced this. After fixing both of these leaks - still have the running rich issue. I’ve also tried another pair of AFM’s - no change here After pulling off the front turbo intake pipes, there is obvious shaft play in the front turbo, which now hisses loudly on light revvs although I can’t see why this would make the car run funny even under idle. I’m curious to know why it’s running rich before I potentially replace/rebuild turbos. The car is completely stock <50,000kms  other than an exhaust. Oil and coolant are all clear. I haven’t bothered with coil packs as it looks like they won’t be the issue due to condition of the plugs. Any help appreciated as I cry myself to sleep!
    • No probs at all. I used to love trying to dig up obscure info for those in need where possible going back 20+ years on SAU.  I did have another look and couldn't come up with any closer match. I'm leaning towards those skirts in your first pic are custom fitments, cut down/extended or from another car entirely and modded to fit an R34 sedan. I would've thought someone in Japan had them and taken a photo at some stage over the last 2 decades but there's nothing. Someone out there must know surely.
