reminds me of a cricket scene from comedy inc where the rangas are in the changeroom ready to bat, but no one wants to go outside in the sun, everytime ones goes out they leave a ball on middle then run back :)
well the aircon in the house just broke lol
looks like im sleeping in the pool
pool or the beach is a awesome idea
apparently there is going to be sea breezes in the afternoon
still not enough to cool the in land....so pretty much embrace for a warm night tonight
If the Americans still don't believe in global warming i think we should bring them over here and strap them to a cricket pitch. Last year was the longest period of consecutive days above 40 on record and this year is looking like it's going to be up there as well.
P.S. i want winter back again. Not that we really get winter anymore
thats what happens when you sell shit quality gear, then jbhifi comes along and sells better for cheaper lol
definatly go mate, think about prodigy closing the boiler room........
lol can you say yum cha brands
haha boiler room will certainly live up to its name and to think that I worked so many of them throughout the 90's.......NEVER AGAIN!!
Did you say digital rectum thermometer?!.........it'd be hotter than 58 deg up there buddy boy :D:P
It's currently 45 deg out there Steve.....hottest January day in 70 years apparently!
defiantly 58degs on the roof i used one of these to take the reading
so, ill be re-painting my aquarium cabinet before i set it up, whats the best way to prep it?
spend the time sanding, including the crevices a fiddly bits (alot of work :P)
or give it a light sand, wood primer, then paint?
seeing as i have some time onb my hands and the shed isnt much warmer then the house, i might as-well get started!
    • Stop looking at the garage floor, and turn the radio up a bit louder if there's any strange noises...
    • No. Turbo shuffle and surge/flutter are not the same thing. Specifically, on a GTR, turbo shuffle has a definite meaning. On a GTR, the twin turbos are assumed to be the same thing and to operate the same way, exactly. In reality, they do not. Their exhaust sides are fed and exhaust a little differently, to each other. Their inlet sides are fed and exhausted a little differently, to each other. Consequently, when they are "working" they are often at slightly different points on the compressor map compared to each other. What this means, particularly when coming on boost, is that one of them will spool up and start producing extra flow compared to the other, which will put back pressure on that other compressor, which will push the operating point on that other compressor up (vertically). This will generally result in it bumping up against the surge line on the map, but even if it doesn't, it upsets the compressor and you get this surging shuffle back and forth between them That is "turbo shuffle" on a GTR. It is related to other flutter effects heard on other turbo systems, but it is a particular feature of the somewhat crappy outlet piping arrangement on RB26s. There are plenty of mods that have been attempted with varying levels of success. People have ground out and/or welded more material into the twin turbo pipe to try to prevent it. Extending the divider inside it works, removing material doesn't. There are aftermarket replacement twin turbo pipes available, and these exist pretty mush purely because of this shuffle problem.
    • You can temporarily* use lock collars to keep it in place until you can do the bushes, back the nuts off, slide them in, snug back up. *temporarily is often for ever
    • Thanks for the quick reply. To be clear, when you say turbo shuffle do you mean turbo flutter "stustustu" or referring to something else? I had thought they were the same thing. When I wrote the post my intention was to say it wasn't a flutter/compression surge sound. My understanding was that a flutter sound would be occurring when throttle is released, whereas I can keep the throttle in the same position for this noise
