The end of the cricket was bloody awesome - apart from the fact that we lost.
Very exciting game though - never thought we would post such a low total either :sick:
Not liking the cricket is unAustralian and should be against the law. Fair enough test cricket can be a bit slow at times (that what all the beer drinking is for), but the one dayers are all action.
test cricket can be a bit slow at times (that what all the beer drinking is for), but the one dayers have plenty of moments. If you get bored watching Twenty20 then you need some dexxys to treat your add
Fixed :sick:
Cruise was good. Lost the main pack, 'borrowed' Luke ENR-034s map then we went for a nice drive through the hills then I went home. I absolutely love having a stock car, pulled into the meet point car park, looked at the multiple cops at every exit and just laughed :(
they feel good?
So far so good, i haven't had a chance to really test them out but atm its staying very flat through corners and im getting a bit more feedback all round.
what sort of settings can you play with?
Height only, everything else is preset. as far as settings go i cant find any information on these coilovers as they were only ever sold in japan and in limited amounts too apparently... majority sold had spring ratings at 9kg front 7kg back that's about all i know.
Other noticeable feature is a double spring setup, i haven't seen anything like it before. Should have grabbed a few pics before i put them in but heres one I found on the net for an r32 GTR
helper springs. pretty common. they compress completely flat when the car is on the ground and keep the main spring captive when it decompresses.
Edited by scandyflick
i work at a tire store.
yes you do need a wheel alignment your toe, caster and camber need to be adjusted.
not that expensive, and can save your tires.
i disagree if you setup up your ride height to a similar to factory height you wouldn't need and alignment if you say take an inch or 2 out you probably might
cricket and paint are 2 of my favourite things... =P
honestly cricket wont hold my attention for long, but the end of the one dayer was right down to the wire.
certainly much better than tennis
you not ment to sniff it :sick:
tx3_90 - nice looking coils
But its an >ENGLISH< game. Give me Aussie Rules Football for a slice of dinkum australiana
-D
    • Have you flushed the initial fluid yet? It should look like a rainbow unicorn shat glitter into it. 2nd or 3rd fluid change is when you party.
    • all brand new unit from Tomei, fluid, bearings, etc. Tomei said they call it a 1.5 lsd because its 100 percent lock up under acceleration and 50 percent under deacceleration.  as I mentioned I used their fluid, install and their break-in procedure, (alot of figure 8's) but even when driving straight, or even slowly backing out of garage for first time, (at 2 mph) then driving to and from figure 8 parking lot, each tire in the rear would sporadically grab, skip, bounce, shutter and skip, shutter back a force I could feel causing clutch to slip then grab, at any speed. shaking entire car. I removed unit, since I put stock back in and all is fine, via process of elimination, its something with the lsd unit itself. I wasn't going to beat up the entire car more or change anything else for no reason as I had a feeling something in the lsd itself was wrong as everything was fine before this alone was installed and I rechecked over everything else after first time backing out I suspected an issue. I'll probably sadly already need new tires now just from trying to drive it 5 miles and performing the figure 8 break in. but if someone has any ideas I'm all ears
    • Ok thanks..that was my second question if i can somehow bypass this even with Nistune(that is all i have right now...aparat from stock ECU. So with some aftemarket it can by "bypassed" or make it work?  I know there is Link or Haltech (mainly used). We have ECUmaster here so i will gather some info about it.
