They also hire via Hays Recruitment. Most government agencies go through Hays as well.
Ring them up or send in your resume to them. Seriously.
They get you a Project Officer, Business Analyst (same shit) or Project Manager job in government in days! And you can name your hourly rate!
Don't be afraid to ask for $30+ an hour, because they pay it!
no - now he has a tyre filled with flammable gas .... great idea
i must've forgot to mention how great of an idea it was in the original post...
I shared something i found, that i thought was interesting. no need for sarcasm
Nah I wasn't having a go at you for a second mate - it is a great vid (I have watched it a few times in the last few hours for giggles).
However, you have to question the intelligence of the clown doing it - I would be uber scared of losing an arm or 2 :wave:
lol dan i meant the 33 in the pic, not your car, i wouldnt dare turn against the midnight blue, i would be burned at the stake lol.
On another note, anyone keen on joining in a track day im organising at mallala? will be a combination of drift and grip, 30 min intervals between each. $300 each, have the track or a full day, booked in for march 26th.
If anyone is interested PM me.
ah man, the 26th is the day i go up to the gold coast!
otherwise i would have joined in on the track day! as much drifting i can get in the better haha.
on private track days do they get rid of those gay tyre's on turn 1 and before the straight?
its an easy way to bead tyres on to wide rims for the stretched look. what wasn't included in the video however is that once the burn is gone you have to quickly jump on to an air line and fill them with air as they suck back in and go off the rim in no time.
have done it before...
Ah. Off to get a haircut. Hate getting it done.
I'm only asking them if they've had a busy day... not their period cycle or anything.
lol they actually get trained to talk your ear off and generally think they are improving your experience.
time to start applying for those project officer position boys
its an easy way to get into the govt even if your on a ASO2 position
at least its something and you can get access to better positions once you have a year or 2 worth of experience in any particular field
Epic shit:
Yeeeeep yep yep yep yep yep yep yep uuuhhhh huh uuuuhhh huh uuuuhhh huh uuuuuhhh huh
Yeah, now you're speaking our language.
[20:13] Dohmar: yepyepyepyepyepyepyepyepyepyepyepyepyepyepyepyepyepyepyepyep
[20:13] Dohmar: Radio!.
[20:13] Dohmar: UH HUH
[20:13] Cara: yepyepyep
[20:14] Dohmar: Radio.
[20:14] Cara: yepyepyep
[20:14] Dohmar: UH HUH
[20:14] Dohmar: yepyepyepyepyepyepyepyepyepyepyepyepyepyepyepyepyepyepyepyep
[20:15] Cara: uhuh
[20:15] Dohmar: uhuh
[20:15] Dohmar: Radio.
[20:15] Cara: yepyep
[20:15] Dohmar: yepyepyepyepyepyepyepyepyepyepyepyepyepyepyepyepyepyepyepyep
I hereby accept next years nobel prize on behalf of SAU.
-D
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
