went to main north nissan today and got the price for every stud, nut, and gasket between the engine and dump pipe. looking at just under $450 for the whole lot.
:EDIT: steve, check this shit out.
Edited by scandyflick
i mean cmon, look at the poor 33 they use in those chip advertisements
123977480_tp.jpg mmm, futuristic.
and the instructions:
"just take it to a TV repairer and have them solder it in"
as opposed to a, mechanic?
R34 chrissy today,, 4 brand new shiny RDA slotted rotors just rocked up...WOOT WOOT
just in time, the front factory ones are cracked to hell..lol
Yeah I gotta get mine replaced so I'll be lashing out for a set of RDA front slotted rotors too. Theyre not as expensive as I thought they'd be either.
-D
    • So sadly the fuel pump etc was not it. The pump and filter is new and it is still cutting around 4000 rpm. A read something about ABS/TCS (engine is from stagea and ECU too so no TCS) and i dont know for 100% that my car has ABS. It has ABS "cube" in engine bay but i dont think it works(or at least from my braking experience). Can be something like that?  I will be driving the car next week to Nistune tuner to properly see what is wrong...
    • the Tomei LSD fluid with lsd kit. frustrated that it was shaking the car to crap and affecting everything else negatively, I pulled the diff last night, and removed the lsd carrier, could not find anything wrong, however it seem to be 100 locked up acceleration, and deacceleration, wondering if they sent me a 2 way not a 1.5??  either way I installed the stock open carrier back in place. test drove everything smooth as butter again. no shake, shutter, random, what felt like clutch slip and grab or drive shaft play, etc. something differently wrong in side the lsd. I might bother taking it apart (if possible) to figure out what's going on inside this carrier, as bought too long ago to return.  only draw back is its back to a one wheel wonder.
    • If there's oil in with the clutch, I hope it finds its way out even if that hole has a cover/grommet 😛 I don't want oil near my cars clutch! 😛 Interested to hear the answer about covering it, I'm assuming a bung for a gearbox from another car that has a grommet to suit.
