thats not entrily true there is a mod you can do
GWW can bench test it i imagine most other workshops can too
ive booked the car in for dyno day @ grahm wests today.
the misfiring is not as bad anymore, drove the car to uni and back, then for another test run and seems ok. there's a split second of misfire but shouldn't be too much of a problem. Ill be getting the silicone insulator on the coils over the weekend and my afm cleaned up.
when i get my exhaust done ill look in to getting a toshi map, or an safc... don't want to spend thousands if all i'm after is not too much more power than its already making. don't want the car for straight line speed, want response and a steady power band.
http://www.skylinesaustralia.com/forums/Ca...ans-t68174.html
good read, SK offers some bang up advice.
this is the link you lot are after http://www.skylinesaustralia.com/forums/Ca...html&st=20#
So i have read up quite a bit on the use of a catch can today, and i came to the conclusion that its only good if the catch can is somehow vented, which is not legal. Another conclusion is that my setup is doing sweet f**k all, and am considering selling my catch can to plan for the future. 70 bucks, takers :P
So i have read up quite a bit on the use of a catch can today, and i came to the conclusion that its only good if the catch can is somehow vented, which is not legal. Another conclusion is that my setup is doing sweet f**k all, and am considering selling my catch can to plan for the future. 70 bucks, takers :D
We have a for sale section you know :P
:):P:D
Edited by RubyRS4
At work today thinking about next yr. Wondering if i should save up spend 10k on a engine or spend a month holidaying in Japan.
hmm hard choices.
+1 Japan, been there twice and look forward to another visit sometime in the future.
I have sacrificed my washer bottle for intercooler piping. What else will fit in that section? Having a daily requires me to use it from time to time when rain dries on the windscreen.
my mate can fabricate ya a washer bottle if ya want one there
yes please!
have to work out a time when he's free, and he can look at the space ya got. does his fabrication work outta his dad's shed at virginia (where my cars are being stored, and is the same guy who made my trailer)
I would also like a washer bottle that fits in despite my ic piping. I assume if Damo got one made up it would fit my car too? I can supply my oem washer bottle motor if he wants to integrate it (which would be preferable).
I had to lol
After Gates Timing Belt + Tensioner Kit for RB26 before Friday.... new only... pst me if you got one
-D
is that like
[quiet voice]pst hey buddy i got a gates belt if you want it (looks around) going cheap (looks around)[/quiet voice]
