Ben you've made half a point and have made it well.
All I can say (can't speak for the other Mods) is that certain older (non car related) threads will run their term and will then be appropriately locked or continued in Wasteland.
ps.
dale.. i wanna talk to u about setting up a reliable ca18det for my keto.
Talk away, It pretty much the luck of the draw though as i was saying it depends on the history of the engine. So unless you are going to start with a rebuild then there is no guarantee that the engine you have will be reliable. The thing is that CA's are relatively cheap to rebuild, for around $2500 + machining (but i have some parts already) i can have a bottom end that will easily hold 250-300kw+
Edited by D_Stirls
Pete I think the answer is to create an Off Topic SA section so people can create nonsense threads and and every one else isn't exposed to them. Do what NS does and make the section a non post count section, hell if this had been done from the start Damo and a few others would only have 5 posts and not the thousands currently they have (not that post count means anything).
We are all member of the "modified/performance" car community but that doesn't mean that we have to always talk about cars.
Amen to that.
CRoNic...
got link to that ca18det on ns.com?
Ahem, I think it was I that alerted you to said CA package :(
Just finding it now, but NS is running like a CAde auto with fked coilpacks at the moment....
Here 'tis
Edited by AndrewJZX100
i founds supecharger!!!!!!!!!!!!!!!!!!!!! zomg!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
who makes it ? does CAPA sell them out of Berri?
that would sound hot, whine at the lights...lol people wouldnt have any clue what is lurking under the bonnet...lol
Jason Gilespie:
"You don't need to warm up your car. Warming up your car, in my mind, is a waste of time if you're running Castrol oil"
Good on ya, Jason.
(that was on a Castrol commercial just on)
Hi Jason
Sell out much?
The day I take engineering advice from a cricketer is the day I trust my root canal to a f**king demolitions expert.
Thanks for the fish
Love
Dohmar
not sure about CAPA........this is thru yella terra
cool, you might try calling CAPA, they do a lot of chargers and being somewhat local ..????
http://www.capa.com.au/kits.htm
do you have a link to yellow terra, like to see how they mount it and have access to pulleys still ? and have working a/c still?
I like it when I make only half a point. It seems to synchronize the yin and the yang.
Better to make half a point and do it well than make a whole point and entirely f**k it up
I suppose.
-D
Samir Godzilla,
If you can't go thru with a deal on the sale of my Stagea which you started with your offer, then don't go shopping for cars and don't waste my time.
BTW an R33 is not a Stagea :D
You've been reported to the mods.
    • This is how I last did this when I had a master cylinder fail and introduce air. Bleed before first stage, go oh shit through first stage, bleed at end of first stage, go oh shit through second stage, bleed at end of second stage, go oh shit through third stage, bleed at end of third stage, go oh shit through fourth stage, bleed at lunch, go oh shit through fifth stage, bleed at end of fifth stage, go oh shit through sixth stage....you get the idea. It did come good in the end. My Topdon scan tool can bleed the HY51 and V37, but it doesn't have a consult connector and I don't have an R34 to check that on. I think finding a tool in an Australian workshop other than Nissan that can bleed an R34 will be like rocking horse poo. No way will a generic ODB tool do it.
    • Hmm. Perhaps not the same engineers. The OE Nissan engineers did not forsee a future with spacers pushing the tie rod force application further away from the steering arm and creating that torque. The failures are happening since the advent of those things, and some 30 years after they designed the uprights. So latent casting deficiencies, 30+ yrs of wear and tear, + unexpected usage could quite easily = unforeseen failure. Meanwhile, the engineers who are designing the billet CNC or fabricated uprights are also designing, for the same parts makers, the correction tie rod ends. And they are designing and building these with motorsport (or, at the very least, the meth addled antics of drifters) in mind. So I would hope (in fact, I would expect) that their design work included the offset of that steering force. Doesn't mean that it is not totally valid to ask the question of them, before committing $$.
    • The downside of this is when you try to track the car, as soon as you hit ABS you get introduced to a unbled system. I want to avoid this. I do not want to bleed/flush/jack up the car twice just to bleed the f**kin car.
    • But again, the engineers said your cast aluminium would be fine based on the load that would be stretching that section. Same load stretching the bolts in a flex (not the twist), with a much smaller cross sectional area than the original part you've broken. It's why you'd need to be using higher strength bolts, but that's just making up for the strength you lose with less area...
    • I am truly amazed someone on this planet was able to cycle the pump using a scan tool. I've always ghetto cycled them on Nissan 90s shit boxes by slamming the brakes and pulling the handbrake to agitate the rear wheels enough to cause a speed difference
