Dammjust got back from my regency appointment and failed :D .
Got done for tiwsted brake line but it passed the brake test.
6 x 9 speakers in the back so they cut the metal parcel shelf and parkers and low beam on 1 side.
Does any1 know hwo or where i could get to fix/ put in a new metal parcel shelf???
please help
Can be classed as structural support, so hacking away at that, in their eyes, is a big no no. In some cases, this means the rear parcel shelf needs to be engineered before you can pass Regency. That's happening alot these days.
friend called me today, his sisters boyfriends pimped as dr30 was stollen last night/early morning :P
was such a old schooler look too :)
ill see if i can get more details, was stollen around the woodcroft area though
Why you selling stockies?
Did you get that roll and flare done? How the rims going?
Coz i dont need them, they arent legal for regency so theres no real point in them laying around, a mate of mine wants to buy them too.
Havent got roll and flare yet. Rims going good!!!
You got your XD9 set yet?
What XD9's?... :P
Yeah I got them here. Using them as a kiddy pool for the dog. :)
... its currently there getting a cracked heater core hose repaired... fun stuff
Well got the beast back and while it took the guys a while to get to the rooted hoses, it was worth it. Not only was one ruptured and spewing my precious nissan coolant all over the front diff, but there were two others very close to giving way.... probably I could give advice to anyone with a 20yr old GTR that hasn't yet replaced the hose, now is the time ;P
And now I can drive without my car stankin' like anti freeze and peeing chloroform
woot
-D
    • Seems like a decent result for a modded JZX110. They are bulky in comparison to the 100 and 90 models (which I'd prefer myself) but they are getting very few and far between here in JP these days. Thanks for the detailed review and the import process into the UK. I also have a car which I'm hoping to export from Japan at some stage so it's good to know if someone from the UK was interested in it. By the way the corrosion underneath is par for the course for cars which were located in/near the mountains or along the Japan sea coastline. They get huge amounts of snow every winter and the sodium chloride is used on the roads. Many cars have some kind of rubber like treatment underneath but they tend to limit it to the wheel arches underbody and fuel tank. Suspension arms and sub-frames will have similar corrosion to your JZX110 which is a common sight. See it all the time and car dealers here generally don't even mention it unless asked.
    • If the sound goes away when you clutch in, the 1.5/2 way diffs are just shit, and you are a normal person. The diff is likely "fine" but driving at anything under 30kmh is a violent horrible experience. It would be exaggerated with solid diff bushings and subframe bushings if you have those.
    • Trailer got new mudguards to accommodate the new wheels Lightweight ally Painted, stickered and done ✅ 👌
    • Did you hit up the search function? R33 and greddy and cable returns this thread with some options.   https://www.sau.com.au/forums/topic/358214-rb25-throttle-body/
