He guys. On my RB25 neo, Whats above the alternator and can leak coolent? Water pump? Ive got a slight leak coming from there. Nothing big just annoying. Could be a gasket i guess to.
Anyone else had this problem before?
Thanks Luke
Heater core perhaps... depends how the neo is laid out. ive just fixed a coolant leak from behind the rb26 which was heater core, replaced 3 hoses... cost a fair bit cause they had to remove the starter and some other shite to get to it, but im glad its done... i lost 2 litres of the nissan coolant, and that shyt is $14 per litre ;|
-D
Thanks Luke
ah top hose, temp sensor, could even be thermostat or lower hose. If it was water pump it would be more likely to run down the side of the block.
^^^^^all these plus
havent looked at mine but the RB's have a hose under the intake plenum for coolant, hides slow leaks well? and they rot out, comes out near alternator or starter area
waterpump leaks end up under the front pulleys area or on the ground below front covers, check the weep hole under the pump, pretty sure the neo have one most cars do. if the fan rocks a tiny bit when you wiggle the fan the pump is on the way out? could be a day or a year?
we can have a peek if your coming to show and shine ?i have a coolant leak detector, let me see if i have batteries for it, bring it if i do
haha the rick rolling started tonight on the 31 forums..ah.. funny stuff..i got sum people aswell...ah i am the king!
until you have people asking to have you banned and start receiving pm's from mods to knock it off, youre not.
just found your rickroll, im surprised more than one person fell for it, talk about poorly executed, saying "dont ban me" sorta gives the game away.
Edited by scandyflick
Cheers guys, Its running down the drivers side of the block all the way to the sump and staining it. Looks like its coming from the block near the alternator.
Hope its not to hard to fix. Might do 100k service soon to then.
I think its easier to learn something when you have some kind of physical application to cross reference...
You can read about something as much as u want, unless you actually see how it works in real life you won't understand the references
At least thats what I've found about myself... I could read a whitepaper 10 times and still not understand it.... attempt to implement it on a running machine, while maybe breaking the system, I'd usually do it in half the time it'd take me to read the damn manual.... then again im a linux engineer by trade and the documentation often sucks so learning the systems yourself are usually the best route anyhow
I agree totally. The easiest methods of teaching is visual, verbal and practical. When I was tutoring Accounting at UniSA, I found relating exercises to things the students did in everyday life helps. If they can picture the application, they can understand it.
BTW I loved maths (I got to, I'm a bookkeeper and drafter for urban planning, which requires numerical skills). One day I'll figure out how to arrange those letters after my name :)
to be honest penny,never even heard of it..lol better google it
I use Castrol Edge for now
I ask because a guy at my work used to import it and now makes it, I have read a bit about it and I like what I read.
Would like to know if anyone has put it to the test here!
www.ulx110.com
ok everyone calm down.
Ripper is obviously young and didn't think about what he was posting or thought about the ramifications.
Ripper, please tone it down.
Everyone else, give the kid a break. I have deleted and cleaned up the posts. No more - I don't have time
www.ulx110.com
Hmmm , I think I would stick to a well known and tested brand
there is a oil thread on the main page to SAU
On that site it says extended oil changes???, well oil also removes crap from combustion and contaminates, still needs to be changed per nissan specs or more if you live on dirt roads or race it.
it looks to be based more for service trucks that get oil changes on time ever time
so many better choices I think???
how much does it cost do you know?
makes it himself???,, what is it from chip shop oil..lol
You implying something here? :)
Its more legit then that haha.
Its sold in a few different Dyno shops, Its around the same price as your top quality synthetic oil so around $75 i think.
They are an American company but he now makes it here (properly in a factory with chemit chemical guys etc).
Im going to do some more research!
    • So for the wide band is a Bosch 4.9 correct for the Link G4+ along with a Can bus? Just get the Link gear or is generic ok too? Eg here: LINK LINK DIGITAL WIDEBAND CAN MODULE WITH BOSCH 4.9 SENSOR : KYP Performance House
    • Bit difficult to follow. Have a look below and see what the standard R32 layout was like. Note there was a restrictor in place immediately before "turbocharged pressure control solenoid" that, if removed, magically got you 1 bar boost.
    • I might be way off the mark here.. there must be a T junction under the manifold. That takes manifold pressure through a check valve prior to the T, one side splits out to this bleed off orifice, the other straight to the wastegate actuators.
    • Carrying out some engine due diligence before my first drive in a 260RS that has been in storage for 10+ years, and found two lines that are susposed to be plumbed into the boost control solenoid. One of the lines (the wastegate boost supply line) to actuate the gates, had a bolt in one end blocking it. The other line (main boost signal line) from the very rear of the intake manifold (RB26DETT) and runs up to the boost controller had this pill in the end of it as seen in photos. Other than the obvious (T28 Ceramic turbos might well be cooked)  Can anyone shed any light on if there is any validity at all with this mod, bleeding a constant fixed rate of manifold boost pressure off through this 3mm hole?  Is it deliberate?  Was this a 90s Jap mod done to RB26's? Or has someone just fitted this without any idea of what happens to ceramic T28s if they are not gate controlled?
