clear?
No, not clear.
Had I not seen the humour side in it I would not have put the ? after stereotyping
Me typing "Stereotyping?" was as if to say..... I think I know what you're on about...!
That's why I think you misunderstood my friend...
hahahaha
you sadistic bastard :)
my uncle has a masive barra, called tiny :banana:
he bores the f**k outta me, just hangs there.
ok then craig if u want cichilds then i reccommend getting "petinenia splendida" (wolf cichild) youtube them........http://www.youtube.com/watch?v=zrkCpqZdq-g
they also have large mouths and grow rather large and also eat goldfish
ive kept these aswell, but they are highly illegal in SA unless u no the right people.................... :blush:
i think you misunderstood my friend...
whan i stated Dominic was clearly a woganise name, i said it in humor,
in which you took as stereotyping.
clear?
Woganise?????????
right-o.
BTW you're all welcome for the awesome entertainment I provided by linking to that forum :blush:
You can thank me by transferring half your stimulus to my bank account :)
haha, lets start an ilegal fish trade, underbelly stylz :)
you know the right people dan?
dang, i missed my sau aniversary
ahahhaha Craig, Im ASIAN.........i can get anything........................................................................
...................... :blush:
ive just resetup my old tank lastnight, undedcided what to get myself actually, ive pratically had most species, at one stage i had 7 tanks setup at once
the fish im after are REDFIN perch
anyone got a dam or private property in the hills?????
I caught and ate one for dinner on Friday night at Waikerie :P - darn good eating too! Used to catch dozens up there when I was a kid, but are quite rare these days - making a come-back in recent years though due to carp eradication programs - have only started catching them again in the last year or so after 15 years of not catching any.
Yes, if anyone has a nice dam on their property up in the hills I am keen-as to come pull some out!!!!
    • It says 300ZX, does that make it an Aus delivered car? Funny how back in the day I just couldn't care less about Z32's and these days I am just in love with them. Back when Nissan was into pushing the envelope. 🤣
    • Hi guys, just after some guidance with an R34 sunroof that has stopped working correctly. It still opens and closes perfectly fine, but it no longer tilts/vents up or down. As a result, the rear of the glass now sags a bit as it drops down slightly in order to retract into the roof, but now it can't pop upwards into a flush position. I’ve probed the pins on the back of the switch connector with a multimeter and it seems like both switches (for open/close and tilt/vent) still work correctly. Any ideas on what it could be, or where I should even start in terms of diagnosing? I'm sure someone's had this issue before but I haven't been able to find anything online relating to this specific issue, most of the issues are with the seals leaking or the motor failing entirely. Thanks in advance!
    • Do you have some data like fuel pressure? It's really hard to say if you're still fighting a fuel system issue at this point. Could be something weird like the FPCM dipping out.
    • Yeah in that case, pulling the dent out. Event a very slight dent can create a lot of work filler-wise and there is a strong chance the panel won't be the factory shape when you are done (as the dent will result in a new high point created somewhere, then everything is brought up to that new high point... but the panel shouldn't be that high if that makes sense).  So you've filled and primed the panel and it is flat, why would you go back and remove the primer and add more filler?
    • Something else I have been faffing with while the car was off the road is making the AC work. Assuming the car isn't at a thermal limit the idea of having AC while waiting in line to go on track sounds delightful. I have actually been lugging around the weight of the entire system since 2018 when the RB25NEO went in without it working at all.  The main reason was in the first few events before I got around to re-gassing it the rubber hose that runs under the manifold had the factory heat wrap/sleeve fail resulting in this: ~2 years ago I purchased a complete used R32 AC line set but when I finally went to install it the line i needed was different where the expansion section is I found a local place that was able to replace the rubber section and re-crimp. They also added some modern heat sleeve to the hose Tight fit but fingers crossed this is the last physical piece of the puzzle needed
