how big is yours dan?
tank that is....
cant ya buy redfin perch?
ummmmmm its only a 2 footer, cant be f**ked with the maintainence of a bigger tank setup atm, just wanted sumthn small in my room to look at
redfin perch are a introduced pest like carp, so they are illegal to sell so the only way u can get them is if u go catch them yaself
if u want a hand setting up or wateva let me ill give ya a hand
u got a intenal or external filter??? the 2nd one i hope
What about my missus Andrew? She's got a dam on their property in Kersbrook, would they have them?
yeah I hadn't even thought of Allanah's parents place. We should give it a try! Is the water fairly clear (suitable for spinners/lures) or dirty (better suited to yabbies and worms)?
Well... Dancing AND acting like a retard... :thumbsup::P
Nah, the real story behind it is me and a friend were doing a photoshoot and he was messing around with his camera and got it to take multiple shots per second, so I did the dance, made a gif and posted it up on here for you all to laugh at, aren't I great?
f**k knows, don't spend much time outside looking at the water :thumbsup: Mostly bouncing up and down on the kids trampoline if I'm outside. I'll be sure to take note next time I'm there
vote 2 krishy spammer of the week :P would of been 5 but luke ruined it
Justwas bring up the track again and the fact that our road safety minister refuses to produce his sources for his fictional stats and then persented the NSW stats that show that there was a 80% reduction in "hoon" offences after the opening of WSID. Also said that there is nowhere for kids to learn to drive and that there is no complusry driving training if the government were serious about saving kids this would be the first step to implement. Said that kids where whaning to learn how to get themselves out of driving situations thatis whytheyare putting themselves in them on the roads as there is no other place for them to do it in a controlled environment.
There was more but the keyboard at work sucks and i can't be bothered typing.
    • Lamb roast on Saturday will be different 🥲
    • They are under bucket shims. Tomei provides a test shim kit and then any measurement of shim required.
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • I couldn't agree more. I should have started from the get-go with a NEO or solid bucket conversion. I started looking into converting over to solid lifters yesterday. Now for some reason I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  But I see no mention of this on any of the Tomei documentation. It just states that I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
