Okay, so get this. I was noticing that my forum posts were getting a little pale, and washed out, so I went to the local office supply store to get a new ink cartridge for my keyboard, and, would you believe it, they didn't have any. I mean, I know my keyboard is getting on in years, but is that any excuse not to carry the refills? Do they really expect me to buy a new keyboard every year just to keep up with them? Anyway, I figured that maybe it was just well hidden, so I cornered a clerk and asked him where the keyboard refills were, and he just stares at me! So I ask him again, and he says he doesn't know. So then I ask to talk to the manager, and he says he'll go get her, and as he's walking away from me I can clearly hear him laughing under his breath. That's just rude.
Moments later Linda, the manager, comes out, and I ask her where the keyboard refills are, and get this: She tells me that they don't exist! Now I've had to put up with a lot of crap through the years as a consumer, but this was a new one, even to me. I mean, if you don't carry the damn product, just admit it! Don't lie to me just to cover up your failings. I mean, does she think I'm an idiot, or something?
Anyway, to make a long story short, I don't think I'll be shopping there anymore. I would go into more detail, but it suddenly occurs to me that I need to go order a new ink cartridge somewhere online before I run completely out of ink.
CA18DET, loom, t28 turbo, fmic, full exhaust, ecu, surgetank setup with external pump also, aftermarket manifold and gearbox.
its a full drop in and go!
wats it worth?
Edited by rad32
wats it worth?
Ill sell you my complete 220kw CA18 setup but you aren't going to like the price. Cost of the parts including engine, trans, GT2871R, 1200kg extreme clutch, exhaust, inter and oil coolers including hoses and piping loom, custom billet parts, tuned ECU (3 day tuning) basically everything you need is $10,400 and i'll be selling it for a bit over half.
PM me if your interested. LOL
Edited by D_Stirls
are u one of the girl guides that helps with the flags at dawn service...
i hope it f**king pours
except when we're outdoor doing dawn service. but if it does, so be it.
bacon n eggs with the diggers is worth a few drops of h20
-D
nah, not dawn service my friend. we're armed and not so dangerous for the main march (read: rifles but no ammo unfortunately). keep an eye out near the rear of the march for the current active units. I'll blend in with the rest, but i'll be in amongst 3rd Field Squadron, Royal Australian Engineers
ahh. they given u a 303 SMLE or a FN FAL ?
I used to do that march when I was an army cadet... a loooong long time ago
was always an interesting day
-D
Freebies anyone? I wouldnt use it personally but hey its free use it on a daily or something haha http://www.turtlewax.com.au/sample.php
still waiting on my chamois from last year... wonder where did that go...
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
    • For race cars, this is one part where I find having the roll cage bar having gone through a hole in the floor better than the build it up on a ledge inside... The Merc I help on, the main hoop ends are marked on the car, and the jack is marked... Jack goes under a few inches and lifts one whole side of the car up... Removes that fight for long slim jacks for race car duties!   My biggest issue for the daily drivers I work on, is my jacks don't go high enough. The jacks start out on a few blocks, jack it up, then start a second jack under it on more blocks, and then I can get an axle stand under it. My axle stands are presently in use, and are nearly fully extended. The car is sitting with barely more than a cm of clearance to get the wheel off the studs! Sarah's Kluger is the same, as it has an ungodly amount of droop available in the suspension and a distinct lack of good jacking points!
    • Happy? Yep, my to do list is getting shorter and shorter. Either this light approaching is the end of the tunnel, or I'm about to be hit by a train... Ha ha ha   Also, Duncan isn't that far out of town that you need to make a multi day drive out of it. 😛
