Okay, so get this. I was noticing that my forum posts were getting a little pale, and washed out, so I went to the local office supply store to get a new ink cartridge for my keyboard, and, would you believe it, they didn't have any. I mean, I know my keyboard is getting on in years, but is that any excuse not to carry the refills? Do they really expect me to buy a new keyboard every year just to keep up with them? Anyway, I figured that maybe it was just well hidden, so I cornered a clerk and asked him where the keyboard refills were, and he just stares at me! So I ask him again, and he says he doesn't know. So then I ask to talk to the manager, and he says he'll go get her, and as he's walking away from me I can clearly hear him laughing under his breath. That's just rude.
Moments later Linda, the manager, comes out, and I ask her where the keyboard refills are, and get this: She tells me that they don't exist! Now I've had to put up with a lot of crap through the years as a consumer, but this was a new one, even to me. I mean, if you don't carry the damn product, just admit it! Don't lie to me just to cover up your failings. I mean, does she think I'm an idiot, or something?
Anyway, to make a long story short, I don't think I'll be shopping there anymore. I would go into more detail, but it suddenly occurs to me that I need to go order a new ink cartridge somewhere online before I run completely out of ink.
CA18DET, loom, t28 turbo, fmic, full exhaust, ecu, surgetank setup with external pump also, aftermarket manifold and gearbox.
its a full drop in and go!
wats it worth?
Edited by rad32
wats it worth?
Ill sell you my complete 220kw CA18 setup but you aren't going to like the price. Cost of the parts including engine, trans, GT2871R, 1200kg extreme clutch, exhaust, inter and oil coolers including hoses and piping loom, custom billet parts, tuned ECU (3 day tuning) basically everything you need is $10,400 and i'll be selling it for a bit over half.
PM me if your interested. LOL
Edited by D_Stirls
are u one of the girl guides that helps with the flags at dawn service...
i hope it f**king pours
except when we're outdoor doing dawn service. but if it does, so be it.
bacon n eggs with the diggers is worth a few drops of h20
-D
nah, not dawn service my friend. we're armed and not so dangerous for the main march (read: rifles but no ammo unfortunately). keep an eye out near the rear of the march for the current active units. I'll blend in with the rest, but i'll be in amongst 3rd Field Squadron, Royal Australian Engineers
ahh. they given u a 303 SMLE or a FN FAL ?
I used to do that march when I was an army cadet... a loooong long time ago
was always an interesting day
-D
Freebies anyone? I wouldnt use it personally but hey its free use it on a daily or something haha http://www.turtlewax.com.au/sample.php
still waiting on my chamois from last year... wonder where did that go...
    • Jack the back of the car up, pull that wheel off, pull that sensor out, and put a bore scope into the hole to inspect the outer casing, see if anything looks damaged before you pull the whole thing apart.
    • Ergh... So I pulled the speed sensor out again and the tip was shiny so I think it's rubbing the bearing. The bearing contains the magnets for the speed sensor so I think when the first sensor broke it damaged the magnet ring on the bearing.  This is just a Google image, but there is a hole going to the bearing. So when the tip broke off the old sensor I'm guessing it fouled the bearing... As the magnet is only protected by a plastic cover it would be easy to damage it. So I guess I'm doing a bearing again.
    • My thinking is that if the O2 sensor is shot then your entire above described experience is pure placebo.
    • Here is the mess that I made. That filler there was successful in filling dents in that area. But in the middle area. I can feel dents. And I've gone ocer it multiple times with filler. And the filler is no longer there because i accidently sanded it away. I've chased my tail on this job but this is something else lol. So I'm gonna attempt filler one more time and if it doesn't work I'll just high fill primer the door and see where the issues are because guidecoat is of no use atm.
    • Ok, so I think I sort of figured out where I went wrong. So I definitely overthinked it, and I over sanded, which is probably a large part of the problem. to fix it, I ended up tapping some spots that were likely to be high, made them low, filled them in, and I tackled small sections at a time, and it feels a lot better.    I think what confused me as well is you have the bare metal, and some spots darker and some are lighter, and when I run my finger across it, it' would feel like it's a low spot, but I think it's just a transition in different texture from metal to body filler.    When your finger's sliding on the body filler, and crosses over to the bare metal, going back and forth, it feels like it's a low spot. So I kept putting filler there and sanding, but I think it was just a transition in texture, nothing to do with the low or high spot. But the panel's feels a lot better, and I'm just going to end up priming it, and then I'll block it after with guide coat.   Ended up wasting just about all of my filler on this damn door lol
