^^ does he even drive it apart from onto a dyno :/
hahaha yeah
they just did it with all stock stuff and he couldnt brake so they upgraded to the slotted rotors and better pads and that made him stop lol mind u this was all on the street too!
Edited by MissR34
the thing is luke, i wont be tracking or dragging her, she will be dyno queen and streeter.
so ill be going with Brembos and maybe EBC Red Stuff brake pads......
Brembos are great, but make sure u get a large rotor to match those sweet calipers
and avoid the EBC Red's... theyre track pads
if you're streeting, stick to EBC greens/bendix ultimates or the QFM pads
-D
ive been told to stay away from EBC greens cause they are too noisy and create alot more brake dust than the reds?
I used Red Stuff on my R and they were brilliant.
Very clean on the wheels too (ceramic pads), unlike Bendix, and can handle both street (low coefficiency) and the ocassional track day without fade (high temp handling).
Were a bit noisy for the 1st 1000km but quietened down eventually and grabbed those rotors hard and fast!
sick, thanks for that Pete, i rekon ill get the ebc reds for sure :/
rb stickers, dosnt anyone like sleepers these days :/
i prefer the dont need to brag about being able to whip your ass at the lights approach.
but then it might get 1 or 2 bogans to accept they cant beat you and not rev you at the lights
Edited by Inline 6
yeah you make a valid point, but then ppl still dont believe its a gtr anyway. love it when they ask me, if im lying with the badge why would i not lie when you ask me
i did rock no badge for a lil while :/
Edited by Inline 6
    • Mine is all -12, I’m running a dry sump in a billet block though
    • HG's high flow is not "bolt on". The core is shorter, moves the comp cover rearwards in the engine bay. means you have to deal with the inlet plumbing a little bit. This is probably something to consider with every "bolt on" turbo anyway.
    • HyperGear. Just get a high flow of the stocker. Good, reliable, and should bolt on. Yes it will want things like a retune once done, so you need to factor this in to your spend too.
    • Hi. Iam looking for some "cheaper" bolt on turbo on RB25DET NEO. I do not want "big" power just better reliability than the stock turbo which is "fot now" good but is old and i do not think it has "easy" life. One the Skyline here running some "temu" china Turbo but i dont trust those... Thanks!
    • Hi guys, Making some space/cleaning up. A whole heap of random OEM R33 GTR parts and other random bits and bobs. I will update this thread as I go. Parts are located in Moorebank NSW 2170. Pickup preferred but will post at buyers expense. Prices are negotiable. If they don’t sell it will go in the bin. Item 1: BOV return pipe. $40 Item 2: RB26 cam gears. $20 Item 3: R33 GTR torque split, oil temp, boost centre gauge. $100 Item 4: RB26 fuel rail x 2. $20 each Item 5: RB26 Recirc valves. $50 Item 6: OEM upper front arms. $20 Item 7: Royal Purple Max Gear 75w-140 1 quart/946 ml x 5. $50 each or 5 for $200. Item 8: OS Giken 80w-250 diff oil 1 litre. $25 Item 9 Eibach springs. ers-11-140-60-0140. $100 https://www.streetfx.com.au/eib140-60-0060-eibach-ers-140mm-length-x-60mm-id-coil-over-spring?_ga_campaignid=22235933977&_ga_adgroupid=180146800292&_ga_keyword=&_ga_device=m&_ga_target=pla-295238231169&_ga_locint=&_ga_locphy=9071723&_ga_matchtype=&_ga_network=g&_ga_device=m&_ga_placement=&_gcl_id=CjwKCAjwlt7GBhAvEiwAKal0cvkVE_hstv24cDiaICsIk1oznH9zAoJf3By6vR3Tpe7jmByqM6JFHBoCZYAQAvD_BwE&gad_source=1&gad_campaignid=22235933977&gbraid=0AAAAADPiTbo1xAuvnjIWWYnezivf-BUSY&gclid=CjwKCAjwlt7GBhAvEiwAKal0cvkVE_hstv24cDiaICsIk1oznH9zAoJf3By6vR3Tpe7jmByqM6JFHBoCZYAQAvD_BwE
