Cara you will need to sell your wheels to clear the brakes. You will need 18x8/18x9 +30 at the highest. Even my 18x10 +18 on the front, another 1-2mm and it would hit. Just make sure u choose the right offset and "disc" design on the wheels to make sure it clears.
Screw spacers, dangerous, stupid and illegal. Not to mention, if you are caught with them in an accident, insurance companies aren't generally too happy
Just get rims that fit correctly in the first place
Regardless, if I were to drive a car anywhere I wouldn't do it with spacers... that's just me though
yeah i just removed mine a couple weeks ago... the wheels look a bit better without them in my case...
cara dont u have 19's ? surely that should clear the calipers?
-D
Just because she has 19's Ben, doesn't mean she has a decent enough offset to clear larger calipers.
Good idea Steve, but I still don't think they are legal
not by rule of thumb but most 9's have a fair amount of caliper clearance considering people often need the bigger rims to clear the big calipers/bigger discs... its a chicken/egg thing
and ive seen her rims, theyre pretty bloody huge :laugh:
-D
Edited by Dohmar
i wouldnt say bolt on spacers are dangerous. I used 25mm on the back of my 31 while drifting for quite some time. They will be going back on the front sometime soon also. Never had a problem. Just make sure you buy hubcentric and get them from somewhere reputable. Adelaide tyrepower is where i got mine from.
cara, if youre spending $xx,000 on an engine package, $2k for some low offset jap (or china, whatever) wheels isnt that much of a stretch is it? sure spacers are a good short term fix, but buying proper wheels would be better.
but then, thats me, im getting annoyed running 5mm locating ring. :down:
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
