taaa..
someone may have taken them apart and sprayed the inside black and then put them back together.
or maybe im lucky to have N1s or Base headlights - wishful thinking...
DSTROY, Ive seen you around south before, alot, infact i even seen you heading into Clarendon ;D if you know the roads im talking about (one past CherryGardens )
thought n1's were non projector?
either way, i wanna do that to my headlights.
bah! wednesdays just arent my day. ticket is paid for. and now i cant go. stupid retarded friends who cant control their tempers. sigh. damage control here i come.
Edited by scandyflick
taaa..
They def ain't normal GTST headlights
Yeah i live near Woodcroft Shops, so i'm always heading up into the hills, no better place to drive a Skyline :P
Finally picked up the new rig last night, all i want to do is drive the thing non stop :D
Edited by DSTROY
still say you need the 'hearst' license plate :laugh:
pay your respects to the furneral ride
speaking of ppl snaking ya luke, i still owe ya cash mate and you aint getting it :( thats how i roll mothr fkr
Edited by Inline 6
^^^^ easy there Tiger .... people will actually start believing that we are fudge-packers .... especially after seeing Heslo in the drag getup :puke:
i think we all had an idea WAAAYYYY before the brownies incident
that was just the icing on the cake or if you will the hot fudge on the brownie
lol
nice
movie looks entertaining (non-treky here)
awesome stag. I live down the rd from woodcroft, wheatsheaf rd childcare / walkway area.
hit you up for a blast once Im done with the turbo tune
I am definitely looking forward to seeing it, but not sure I can get over Sylar being Spock :wtf:
Yeah I'm heading to the drive in tomorrow to check it out... can't wait
toying with the idea of watching wolverine too
7:15 at gepps cross drive in for anyone keen to come :D *looking at dan*
-D
    • Ha, I've never pressed the X in all these years incase it removed the notification for all Admins
    • I don't know, I've never done it that way, but 1. While it is an interference engine, there is still clearance between the valves and the piston at all points in the regular timing cycle 2. There is not a lot of distance before you can't catch the top of the valve stem any more I don't know if 2 is greater or less than 1. But 3. If it doesn't work out you are f**ked, engine is coming out to disassemble so it is a big bet.
    • Semi slicks are horrible for road use, just use a high performance road tyre unless you really need the maximum grip. Noisy, unpredictable (amazing, until they are not), expensive due to very high wear and not good in cold and particular wet. And yes, it is a thing to store cars on stands instead of tyres if you know they are going to be parked up long term.....but who ever realises that a short park is going to stretch into years before it is out again!
    • I know in Australia you'll definitely get above 30c. Parked in the shade in Summer you'll be above that. 😛 But in cooler climates, you might get that warm driving on the highway for a bit, but you'd never get to full heat temp. I'll try and find some of my historical tyre temps between Aus summer and winter (be aware immin the warmer area of Aus too.)
    • I get that taking off the head is best but that's a bit much for "just" valve seals. I was just under the impression that one would be able to rotate to TDC and be able to temporarily drop the valve without losing it and effectively having to remove the head to then recover it. I never knew people actually pushed rope into the cylinder to do valve seals hahaha So just to confirm, just going to TDC will not work? In that case I know when I do valve seals I'll maybe just remove the head and do some other things while I'm there, or just wait until I do an engine build.
