Does anyone have or know of anyone that has some bolt-on spacers lying around I could borrow for a short time to see what size I need? I would really like to see some 20mm's on, but don;t want to for out the cash for some until I am sure. It would be much appreciated.
ive got sum 5mm spacers here brand new u can buy for $15, nothing special brand got them from sprints auto
hey all... just quickly..
pulled the CA18det out of a bluey, running 100%.
put it in the rolla. now i idles like crap and missfires..
changed plugs..
what could be the problem?
any ideas?
was your car at "complete exhaust" (carline) today adrian???
saw it there this morning while i was getting my external gate screamer pipe open to atmosphere again by Michael
he does GREAT work there at great prices
that it is all.
My name
Is flubba bubba wubba jubba noongahhh!
Im BACK
Run! Run! Run!
Run Gordon!
Its the policeman, we gotta get up out the jails its policeman
grab ya bong, get the weed, its police man!
-D
Does anyone have or know of anyone that has some bolt-on spacers lying around I could borrow for a short time to see what size I need? I would really like to see some 20mm's on, but don't want to fork out the cash for some until I am sure. It would be much appreciated.
I have some 5x114.3 20mm spacers you can borrow but you will have to find some nut for then as i have used the nuts for the spacers i made on the CNC.
morning all!!!!WOOOO half day today...got the wifes falcon and a trailer load of rims and tyres that i have to swap over down at grand auto...pick up a battery....load the kids motorbikes and get ready for stansbury....i bet this morning will go slow as hell now :)
Collected 2 of my Design and Construction Management projects last night from my lecturer and scored top marks! :):ermm::banana: Funny thing was that I was worried I had left some detail out.
Projects required compiling a Site Analysis Report detailing everything about a development site from a site visit and survey. Next part of the project required the design of a single storey dwelling on that site, complete with all drawings you'd submit with Council for Building Rules Consent. Ah, I felt like bragging. Not often you get 100% from design projects. :cool:
Now I just got another 2 to go!!! Time for beer tonight!!!
[end bragging] :P
Edited by RubyRS4
yep that was mine!
and yeh he does! and FAIR cheap!
Today is not a good morning for me.....got into work and so much is needing to be done that its not funny.....plus going for another interview at 3pm then go home and clean the 33 for tomorrow......
here is a pic of a single story dwelling.
But thats only the front elevation! :banana: You haven't labelled the roof pitch, or dimensions of the window and door framing and the pier and cavity locations for those openings. You'll also need to annotate the construction materials and dimensions. Is it steel frame or timber frame? What grade wood?
Where are the site plans, elevations, floor plan, section plan etc?
And on and on ... :cool:
E- for your efforts :)
lol.....i spose that's what youd expect from a magna driver....jk
:ermm:
Edited by RubyRS4
    • Ok thanks..that was my second question if i can somehow bypass this even with Nistune(that is all i have right now...aparat from stock ECU. So with some aftemarket it can by "bypassed" or make it work?  I know there is Link or Haltech (mainly used). We have ECUmaster here so i will gather some info about it.
    • Yes. You will need to get the original boost sensor and wire it in. That is.... if you plan to use a stock ECU - even a Nistuned ECU. The Nissan ECU will not operate correctly without it connected. And yes, it will do annoying stuff like you are experiencing. You will almost certainly be better off with some aftermarket ECU, than trying to hunt down rare sensors.
    • Ok so ABS/TCS is "not" the problem. Yeah i know now about the ABS with Nistune(i told that to the Nistune guy) but iam not 100% why or why i dont have ABS. ABS cube is in the engine (always has been) but i had braked couple of times rly hard and brakes just locked and scream. Does all Skylines have ABS cube? That boost sensor https://www.sau.com.au/forums/topic/367633-wtb-r34-gtt-turbo-pressure-sensor-pics-inside/ Is this it? I need to ask but i have a picture of engine bay and i do not see that (100% is not in that place) If i do not have this the car can do what mine is?(cutting around 4000 rpm) Here is the pic of my engine bay(only one i have) BUT i think i dont have that cuz loom was used from my RB20DE NEO and i know (obviously) that it does not have boost control or any wire to that...) so maybe that is the problem? (i dont know for 100% if that car where the engine is from had that)...but i dont have the loom from that
    • I'm with you here. It's either loom has an issue, OR, injectors are not functioning properly. It could even be they're just constantly dribbling, hence the wet, but not firing.
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
