Does anyone have or know of anyone that has some bolt-on spacers lying around I could borrow for a short time to see what size I need? I would really like to see some 20mm's on, but don;t want to for out the cash for some until I am sure. It would be much appreciated.
ive got sum 5mm spacers here brand new u can buy for $15, nothing special brand got them from sprints auto
hey all... just quickly..
pulled the CA18det out of a bluey, running 100%.
put it in the rolla. now i idles like crap and missfires..
changed plugs..
what could be the problem?
any ideas?
was your car at "complete exhaust" (carline) today adrian???
saw it there this morning while i was getting my external gate screamer pipe open to atmosphere again by Michael
he does GREAT work there at great prices
that it is all.
My name
Is flubba bubba wubba jubba noongahhh!
Im BACK
Run! Run! Run!
Run Gordon!
Its the policeman, we gotta get up out the jails its policeman
grab ya bong, get the weed, its police man!
-D
Does anyone have or know of anyone that has some bolt-on spacers lying around I could borrow for a short time to see what size I need? I would really like to see some 20mm's on, but don't want to fork out the cash for some until I am sure. It would be much appreciated.
I have some 5x114.3 20mm spacers you can borrow but you will have to find some nut for then as i have used the nuts for the spacers i made on the CNC.
morning all!!!!WOOOO half day today...got the wifes falcon and a trailer load of rims and tyres that i have to swap over down at grand auto...pick up a battery....load the kids motorbikes and get ready for stansbury....i bet this morning will go slow as hell now :)
Collected 2 of my Design and Construction Management projects last night from my lecturer and scored top marks! :):ermm::banana: Funny thing was that I was worried I had left some detail out.
Projects required compiling a Site Analysis Report detailing everything about a development site from a site visit and survey. Next part of the project required the design of a single storey dwelling on that site, complete with all drawings you'd submit with Council for Building Rules Consent. Ah, I felt like bragging. Not often you get 100% from design projects. :cool:
Now I just got another 2 to go!!! Time for beer tonight!!!
[end bragging] :P
Edited by RubyRS4
yep that was mine!
and yeh he does! and FAIR cheap!
Today is not a good morning for me.....got into work and so much is needing to be done that its not funny.....plus going for another interview at 3pm then go home and clean the 33 for tomorrow......
here is a pic of a single story dwelling.
But thats only the front elevation! :banana: You haven't labelled the roof pitch, or dimensions of the window and door framing and the pier and cavity locations for those openings. You'll also need to annotate the construction materials and dimensions. Is it steel frame or timber frame? What grade wood?
Where are the site plans, elevations, floor plan, section plan etc?
And on and on ... :cool:
E- for your efforts :)
lol.....i spose that's what youd expect from a magna driver....jk
:ermm:
Edited by RubyRS4
    • Nah, OEM washer bottle and brake fluid reservoirs are fine I don't know what it is with the plastic that Mazda used, some plastics, like the washer bottle and brake fluid res are fine, and still look new after 20 years use, where as the coolant expansion tank, and PS reservoir, that I replaced with new OEM items when I first got the car, turned yellow and started getting brittle a few years later If the dirty yellow stained plastics didn't trigger me there wouldn't be an issue, but they did, much like the battery bracket....... Meh As for going back to work full time to support car stuff, nope, why, because I own a Mazda NC MX5, not a Nissan R series Skyline 🤣
    • I've never heard of CJ-motor, so can't advise you on them. I'd just go straight to GCG for a GCG highflow though. Seems no point to use a middleman. I'm somewhat surprised that the price on the CJ site is lower than the GCG retail price. Even though CJ would get a discount of some sort, you would hardly expect them to give up so much margin. Maybe the price is out of date? Having said that "I'd go to GCG"...when I did my highflow, I went to Hypergear. I did this https://hypergearturbos.com/product/rb25dethighflow/#tab-dyno-results with the R34 OP6 450HP profile. With the BB centre (extra $400) and intially with the standard boost actuator, but I eventually got him to send me the high pressure one when I got to the point of being able to actually use it. Ends up costing the same sort of money as the GCG highflow, but this is, of course, the turbo that I KNOW has a shorter length core and so moves the comp cover rearwards. The GCG apparently doesn't do that. My mechanic also swears by the GCG highflow, given that we have another turbo rebuilder who does something essentialy the same as theirs, using Garrett wheels. He says it stands up at really low revs and makes good power. I haven't pushed my HG highflow past ~240-250rwkW yet (should have a little more in it, but unclear how much) and it does have a fairly gentle boost ramp. OK, it's much better now that I have gotten my boost controller tuned up on it.  A lot of my earlier unhappiness was because I couldn't keep the wastegate flap as closed as it needed to be (including some mechanical issues). I'd still prefer it to boost up nearly as quickly as the stocker, and it certainly a bit slower than that. So maybe the GCG one is worth the first look (for you).
    • Ok thanks 🙂 I will higly consider this. Any "known" company for a good reviews and experience to send that off? Is that CJ-motor good one? Or go straight to GCG site? I need to use VPN to even find some of those "shops" let alone access them 🙂
    • You can literally put in as much WMI as it takes to quench the combustion totally (and then back it off a little, obviously), and it will keep making more and more power. The power comes from the cooling effect of the water (and the meth) and the extra fuel (the meth, which also has massive octane). It is effectively exactly like running E85. One might be slightly better than the other, but they are damn close. But with either you can lean on the boost or the timing (or both) waaaay more than with just petrol and the results are similar. Here's the first thing I googled for an anecdotal bit of evidence. Can't access the attachment without being a gold member, but it is there for the getting if able to, or searched up elsewise perhaps. https://www.hpacademy.com/forum/general-tuning-discussion/show/wmi-vs-e85/
    • Dang, those BBS are so nice!
