Well, I looked, I rang, I browsed ...
There are no type M bars available in South Australia ... privately, wrecking or imported. Fail :P
edit - JIS have one three advertised on their site for $350.
unless its sold... i thought they are usually pretty good with keeping their site up to date with stock
JIS have one advertised on their site for $350.
Depends on how much Paul hassles Koji to update stuff.
yeah, thats what gave me the idea chad. Plus my chances of finding a stock driver seat in the same trim pattern for the same price as a pair of coupe seats + a bit of metal and time for the fab work, its goin to be reasonably comfy too
Anyone know the rough costs of having a worn gear changed in a manual gearbox?
I haven't done a gearbox in years ... and couldn't be bothered doing it myself anyway :P
ruby this is a breakdown of getting my gearbox rebuilt
synchro ring sets-1,2,3,4
input shaft
3/4 synchro hub
synchro keys, spring and sleeves
input shaft bearing
input seal
3rd gear
plus labour in/out plus gearbox oil
total with gst $3,500
got my coilpacks! yay.
That is bad timing - just today I bit the bullet and decided I will sell all the R34 gear I had accumulated, but not yet fitted to my 34. Including a set of Super Spark coilpacks with 3 spares.
Ah ha! Missed them. Cheers, I'm browsing their site now. Will call tomorrow and pick up. :)
These be suitable for 33 series 2 Andrew ?
Edit: Hey Ruby, pretty sure they have 1 series 1 and three series 2 front facia's in stock. One of the series 2's has the factory lower lip on it too.
Edited by Jamesrb25
I've seen that one at JIS - been there for ages.
Tossing up between these 3 that I can see online:
I like this. Complete and just in need of paint.
I can throw this one on without paint for now, being white.
I like the look of the grey S2 with the lip ... but no lights, and will it fit the S1 model?
Dumb Q: is type M and spec M the same thing?
Its meant to be Type M... Spec M is something relating to one of the R34 models.
Thought so ... the two, one labeled "type m" and the other "spec m" looked identical :)
I'd wanna see the bumpers before deciding. I'm also keen on some Work mesh dish rims. :D
    • I downloaded the apps (for windows) and Consult 1 doesn't have this function on it for the Consult 1 plug which I'm pretty sure all Skylines have. You would think someone would have a workaround after 30 years for all Skylines which have ABS.
    • Also, I don't know the actual ABS system on the skylines, but a sneaky thing could be a piece of electronic equipment that makes the ABS think you're moving, and then same piece can send a signal for a locked up tyre... Activate ABS without slamming brakes...
    • The team at OBD2 Australia are pretty good, shoot them an email and ask them. I've dealt with them before for work stuff. I'd be shocked if it didn't work, so long as Consult can activate the ABS. But you might need to use KLine for it which would be the stopper, as I don't think that piece does KLine comms.
    • Yeah and hence my ghetto way of slamming the brakes, get the ABS to cycle, rebleed seems to be a sensible workaround.
    • Hey! Happy to help. Nothing inherently wrong with the adapter, it's more so with Brett Collins himself. He gave me a lot of incorrect information when I was in contact with him and was extremely rude when I challenged him. He stated I could not use any aftermarket twin plate clutches except for his own, not to use the dush shield, bla bla bla and it was all BS.  Collins stated to cut roughly 14mm's off the housing, I took off 15mm to make room for the dust shield. I would confirm with whatever adapter manufacturer you're using.
