Well, I looked, I rang, I browsed ...
There are no type M bars available in South Australia ... privately, wrecking or imported. Fail :P
edit - JIS have one three advertised on their site for $350.
unless its sold... i thought they are usually pretty good with keeping their site up to date with stock
JIS have one advertised on their site for $350.
Depends on how much Paul hassles Koji to update stuff.
yeah, thats what gave me the idea chad. Plus my chances of finding a stock driver seat in the same trim pattern for the same price as a pair of coupe seats + a bit of metal and time for the fab work, its goin to be reasonably comfy too
Anyone know the rough costs of having a worn gear changed in a manual gearbox?
I haven't done a gearbox in years ... and couldn't be bothered doing it myself anyway :P
ruby this is a breakdown of getting my gearbox rebuilt
synchro ring sets-1,2,3,4
input shaft
3/4 synchro hub
synchro keys, spring and sleeves
input shaft bearing
input seal
3rd gear
plus labour in/out plus gearbox oil
total with gst $3,500
got my coilpacks! yay.
That is bad timing - just today I bit the bullet and decided I will sell all the R34 gear I had accumulated, but not yet fitted to my 34. Including a set of Super Spark coilpacks with 3 spares.
Ah ha! Missed them. Cheers, I'm browsing their site now. Will call tomorrow and pick up. :)
These be suitable for 33 series 2 Andrew ?
Edit: Hey Ruby, pretty sure they have 1 series 1 and three series 2 front facia's in stock. One of the series 2's has the factory lower lip on it too.
Edited by Jamesrb25
I've seen that one at JIS - been there for ages.
Tossing up between these 3 that I can see online:
I like this. Complete and just in need of paint.
I can throw this one on without paint for now, being white.
I like the look of the grey S2 with the lip ... but no lights, and will it fit the S1 model?
Dumb Q: is type M and spec M the same thing?
Its meant to be Type M... Spec M is something relating to one of the R34 models.
Thought so ... the two, one labeled "type m" and the other "spec m" looked identical :)
I'd wanna see the bumpers before deciding. I'm also keen on some Work mesh dish rims. :D
    • I hadn't thought about the variable power steering assist. Presumably, it will always be the same level of assist as you get in an S14. The R32/3/4 are either helliishly heavy (at low speeds) if the solenoid is not powered at all, or hellishly too light (at high speed) if it is powered all the time. I presume that it is PWM controlled on those cars. I hadn't thought about the S cars not having variable assist. ugh. What crappy plebby cars they must be!
    • Hmm yeah that is a good point. It looks like it'll just bolt in with no real issue besides maybe the bushings being different. My other concern was that 2 pin plug that I assume is used in some way to control the rack solenoid depending on the speed signal from the ecu. The DMAX rack doesn't even have that plug though so, don't think it'll matter. Might just order the rack and see how it goes. Will update this when I figure something out
    • I'd say it's a fair bet that the feed and return fluid lines will be in different enough spots that you would need to come up with a way to cut the originals short and adapt with new hard line adaption or braided teflon hoses or somesuch. But really, you have the car, you have the photos of the DMAX rack - you should be able to go out there and see for yourself whether they're in the same or different spots.
    • I've been doing some looking around and honestly was just considering throwing a new rack at it. I saw that the dmax silvia rack bolts up into the 33 with the silvia bushings but not sure if the high pressure lines will sit in the correct spot. I believe other version of the 33 rack are the same/similar to the racks that can be opened up without as much fuss so I assume the dmax rack would fit but any ideas?
    • I've never played with one, but I would expect that you are correct. That slot looks like it is intended to be used to unscrew the end, and the flats on the body would be better than grabbing it around the round bit with a pipe wrench. So, yeah, probably unscrews. You'll probably have to make a tool to drive in that slot.
