Mitch, dont let your tits leak, im only trying to help mate.
if you have never appealed a licence disqualification then you are well within your rights to appeal
this one afaik.
Damo, i didnt buy the 31 wagon mate, the oil looked like iced coffee. (cracked head/gasket)
havent got round to changing my profile
Fking maggi 2 minute noodles are shithouse. Baked not fried = failtown. Hadn't had them for fking ages and now I'm reminded why :D
In othe news, Bee*R limiters are made of win. RB + straight pipe + limiter = fun times.
Edited by AndrewJZX100
if you havent had to appeal before you should have nothing to worry about Mitch...
I got done for disobeying a traffic sign, which was 3 demerits - this was quite a while ago.
when i had to appeal, (I attended the Holden Hill court), the court room was packed full of P platers appealing their license, and one by one you get called up, judge reads your letter from employer, and sends you on your way with 1 demerit point. I then got a letter in the mail stating this (last demerit point warning), and i had to attend one of those driving intervention meetings.
i got caught with no p plates.
its a minor frigging thing !
reckon i have a chance of getting off ?
edit// i got done for speeding last october and i learnt my lesson from that , and then i got caught with no p plates in my dads work car.
Well I've looked up the law - says that you lose your licence alone for not displaying the p-plates however it doesnt say that its mandatory.
The speeding ticket will have given you 1-3 demerit points depending on the speed. Now, there is legislation to change the 'not display p plate' penalty to 2 demerit points rather than a loss of licence, however it doesn't come into effect until january 2010. This is where lawyering comes in handy
You can employ a lawyer to negotiate with the prosecuting sergeant as to what charges you will face and if there is any way he can convince them to charge you with a lesser offence. Once that happens, he can delay the court case for a fairly long while, and then once you actually do face court there is a good chance they can point out your virtues and impress the magistrate with character references and the like. A magistrate wouldnt want to take your licence away if you need it for your income, however if the law doesn't allow them to negotiate then I'm afraid its bad luck. In negotiations with the magistrate, the lawyer can request that they extend your P's or put you back to P1 rather than P2 (or is it the other way around?) or put you on a good behaviour bond, etc.. only they know the tricks of the trade which is why its worth fighting for if your income depends on it.
If he can delay your case till Jan 2010, and the penalty is taken from day of sentencing rather than the day of offence comitted, he might be able to get you down with 2 demerit points- however you'd have to make sure that those demerit points wouldn't put you over the allocated amount at that time. The only problem with delays is if your licence has been automatically disqualified and you cant drive at this moment.
-D
picked up some genuine nissan coolant today, so ill probably flush and fill tomorrow. and i mounted my hid ballasts out of the way (stole chads idea), its so ninja spec.
Wing looks ace as fk Dave, digging it.
Give me a yell when your rig is back on the streets, keen to hit up more drives.
cheers dude. will def give you a buzz when its back on the road. itching to go for a drive. its a couple days short of 2 months now.
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
