theres some dam good stuff in the how stuff works videos! i never knew how a tourqe converter worked before this one. he craps on a fair bit but still gets the point across.
http://www.youtube.com/watch?v=Kfksv9jFE4w...feature=related
Ever wanted to know how a diesel engine works?
http://www.youtube.com/watch?v=K9ZkDXadpJk...feature=related
Edited by Jack88
Hey everyone, Im looking at getting a 32 GTR in the next few months, just though id say gday and try to start to get to know some of the SA people. Im keen to come out to meets and stuff when I get a GTR.
cheers Sean
What compels one to advertise shit for sale on this forum then abandon it.....? Got me farked!!!!
that annoys me too.....if it continues to happen where a seller does not reply after repeated attempts over a few days, report their post to me and I'll bin it.
Get licenced up bro and come out on the road with me!
lol, a bike licence? my mum always said she wouldnt let me live under her roof if i got a motorbi...
... scratch that, she dont live here anymore. ill go and apply on wednesday.
umm this is gonna be probably sound dumb for u turbo peoples
but if i get a stock r33 turbo, will i have to get a stock r33 bov to go with it or can i get a r34 one if i cant find a stock r33 bov?
    • Then, shorten them by 1cm, drop the car back down and have a visual look (or even better, use a spirit level across the wheel to see if you have less camber than before. You still want something like 1.5 for road use. Alternatively, if you have adjustable rear ride height (I assume you do if you have extreme camber wear), raise the suspension back to standard height until you can get it all aligned properly. Finally, keep in mind that wear on the inside of the tyre can be for incorrect toe, not just camber
    • I know I have to get a wheel alignment but until then I just need to bring the rear tyres in a bit they're wearing to the belt on the inside and brand new on the outside edge. I did shorten the arms a bit but got it wrong now after a few klms the Slip and VDC lights come on. I'd just like to get it to a point where I can drive for another week or two before getting an alignment. I've had to pay a lot of other stuff recently so doing it myself is my only option
    • You just need a wheel alignment after, so just set them to the same as current and drive to the shop. As there are 2 upper links it may also be worth adding adjustable upper front links at the same time; these reduce bump steer when you move the camber (note that setting those correctly takes a lot longer as you have to recheck the camber at each length of the toe arm, through a range of movement, so you could just ignore that unless the handling becomes unpredictable)
    • I got adjustable after market rear camber arm to replace the stock one's because got sick of having to buy new rear tyres every few months. Can anyone please let me know what the best adjustment length would be. I don't have the old ones anymore to get measurements. I'm guessing the stock measurement minus a few mm would do it. Please any help on replacing them would be fantastic I've watched the YouTube clips but no-one talks about how long to set the camber arm to.
    • Heh. I copied the link to the video direct, instead of the thread I mentioned. But the video is the main value content anyway. Otherwise, yes, in Europe, surely you'd be expected to buy local. Being whichever flavour of Michelin, Continental or Pirelli suits your usage model.
