yeah I sorta noticed the next day.
For some reason a few of us thought weetbix and wine mixed. Also shots. Had to sleep it off the next day at a children s playground in a non-pedophile way
bahahahaha yea iv slept one off before in a random gazeebo along the espy,gotta love the loose nights and using a back pack as a pillow, boy does it get dam cold tho!
can anyone get good deals on 4wd accessories...........tryin to get a good price on some Lightforce lights
if ya can hook me up, im after 2 pairs of Lightforce 170 Strikers with Crystal Blue Spot covers
Ill see what i can do.
its all about having fun and being a wee bit competitive
lol i dont think the guys at the venue like their karts being drifted but go for it.....its only you loosing lap time and speed and momentum and then BAM...Big Bad Craigy has got ya :(
it aint how you stand by your kart
I've never been told off before :)
ive never been told off either including the 1 time i lost it trying to get it 2 far swideways :)
motivational pics
If anyone is after Motul Gear 300 75w-90w 100% synthetic gear box oil i have a 25L drum of the stuff. I'm selling it for $32 dollars per litre. In shops this goes for $43+ per L.
Let me know here or via pm if you need some.
Might give you a yell soon Luke, gearbox is well over due for fresh blood
