anyone know wat ecu i can go for seeeing as i cant find a CA18DET PFC?
and to lock my diff :(
cheers
Anything wrong with a remap?
It'll do everything and more that a P-FC will do (infact it is better as it retains the knock control that you lose with P-FC) with the exception of the hand controller and if you want something like that just pay $400 for a NIStune board and you can plug it into your laptop and bring up more info than the hand controller will give you.
Edited by D_Stirls
I've never been told off before :)
They only tell you off if by sliding you are going to b causing others to crash into you....which can build up to a massive pile up and many karts being broken lol.....best effort in breaking karts at an event so far has been 3 for my events
it aint how you stand by your kart
ive never been told off either including the 1 time i lost it trying to get it 2 far swideways :(
motivational pics
Good motivational pic there Dan
If anyone is after Motul Gear 300 75w-90w 100% synthetic gear box oil i have a 25L drum of the stuff. I'm selling it for $32 dollars per litre. In shops this goes for $43+ per L.
Let me know here or via pm if you need some.
Might give you a yell soon Luke, gearbox is well over due for fresh blood
Let me know when your going to get that coz i will most likely need this done to my line as well
so, im lazy and have only just started searching, but i figured id ask anyway...
... anyone know where i can find ecu pinouts for the s14?
Try NS bro
andrew just gave me a call, he's coming by this afternoon to mock up my t/b intercooler piping, and expects to have it ready by tomorrow arvo. :)
Try NS bro
found it about 10 minutes after i posted. :)
well...after sunday's fuel tank issues...monday saw the car struggling to get fuel which saw me creeping up south road towards junkfood corner at 5km/h :( ....the wife took the pump out while i was at the chiro and i found a few clamps loose that were holding the 040 into the stock cradle...moved the pump up and tightened the clamps and test drover...problem solvered.....so i thought...going to work the next day and was getting surge issues and the car was backfiring and carrying on like a pork chop....took the pump out last night..then went to my mates place to pick up my old "holy" tank to get them side by side..the tank i'd bought was out of a S3 R31...my tank was the same on the outside but different on the inside...so i went to my mate that i bought the tank from..and had a look in the back of his S2....exactly the same as my old tank.....There lies the problem...mine is an early 88....one of the first..so it carried on some of the S2's parts....including the fuel tank :) ....tonight im going to grab the tank thats in his spare car...and friday night swap them over on the hoist at my other mates shed over a few bourbons.......Damn skylines!!!!.....Bloody vintage car...
THE END :):bunny::):bunny::blink:
God I love it when you ghetto repair some drift damage and it actually turns out well :P
Munched the front corner of the sil a few nights ago. Nothing major just a bent guard, scraped front bar and parker light was MIA.
Bent the guard mostly back out, masked up the lights and gave her a quick spray and from a distance you almost wouldn't even pick it :D. Just chucked one of those crystal parkers in there (gay looking thing) for now until I get another stock one from JIS tomorrow - then it should be almost back to former glory :P
Now to make sure I avoid Clems tyres on satdy evening :(
geez, this day is dragging on! anyone got any cool shit to post up?
Your not wrong there Damo.....i thought the clock said 4:24pm but that motherf**ker is saying 3.24 now....this is just not right
    • Input shaft bearing. They all do it. There is always rollover noise in Nissan boxes - particularly the big box. Don't worry about it unless it gets really growly.
    • For once a good news  It needed to be adjusted by that one nut and it is ok  At least something was easy But thank you very much for help. But a small issue is now(gearbox) that when the car is stationary you can hear "clinking" from gearbox so some of the bearing is 100% not that happy... It goes away once you push clutch so it is 100% gearbox. Just if you know...what that bearing could be? It sounding like "spun bearing" but it is louder.
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
