yeah Luke the heater core shat itself in January this year and dumped the entire contents of my radiator into my passenger side footwell (lots of mopping up/cleaning/drying ensued) :) - I rerouted the pips in the engine bay so it wouldn't leak anymore, and have only just gotten round to replacing the core.
The old core had split along the top tank weld line, as is quite common.
Hmm i got water leaking into the drivers footwell, theres nothing in the passenger one. Cant find what it is and got no idea how it gets there. Annoying the shit out of me.
I'll be pulling out my air-con later on and leaving it out all together. Only keeping the rear demister and front windscreen blower.
Dang, so my 34 that I have de-winged is gay? *sob, sob, sob* Ah well, hope somebody buys it anyhow :O .... ask your mates guys - she is going up on car sales next weekend for $21k .... 230rwkw and lots of fun to be had.
My new Nissan has a rear wing :):P .... I fly to Melbourne to pick it up July 18th now ....
I know what it is
Going to reply to pm's or what?
hey hey the swandwich action is only cool when 2 women are involved.
and lol at the quick question thread, sled you aint in control till your outa control :)
LOL Dan, I gave up on trying to control you & Ruby yonks ago :P
Having said that, while Penny is having a laugh with this consider yourself safe........however, if I get 1 PM from her, I'll turn you & Roo into Eunuchs :(:)
yeah Luke the heater core shat itself in January this year and dumped the entire contents of my radiator into my passenger side footwell (lots of mopping up/cleaning/drying ensued) :( - I rerouted the pips in the engine bay so it wouldn't leak anymore, and have only just gotten round to replacing the core.
Told you the whole dash would have to come out :)
Evaluation
You have a total score of 5.
This indicates your patterns of alcohol use do not pose a threat to your health or put you at risk of alcohol dependence.
Would've been a different score back in the day me thinks.
You have a total score of 26.
This indicates your alcohol consumption puts you in position of considerable health risks. You are probably moderately-severely dependent on alcohol. Your doctor may make further investigations, recommend counselling or alcohol reduction strategies.
that is my mates score :|
Having said that, while Penny is having a laugh with this consider yourself safe........however, if I get 1 PM from her, I'll turn you & Roo into Eunuchs :):)
Guess they'd better stock up on straws :(
    • It says 300ZX, does that make it an Aus delivered car? Funny how back in the day I just couldn't care less about Z32's and these days I am just in love with them. Back when Nissan was into pushing the envelope. 🤣
    • Hi guys, just after some guidance with an R34 sunroof that has stopped working correctly. It still opens and closes perfectly fine, but it no longer tilts/vents up or down. As a result, the rear of the glass now sags a bit as it drops down slightly in order to retract into the roof, but now it can't pop upwards into a flush position. I’ve probed the pins on the back of the switch connector with a multimeter and it seems like both switches (for open/close and tilt/vent) still work correctly. Any ideas on what it could be, or where I should even start in terms of diagnosing? I'm sure someone's had this issue before but I haven't been able to find anything online relating to this specific issue, most of the issues are with the seals leaking or the motor failing entirely. Thanks in advance!
    • Do you have some data like fuel pressure? It's really hard to say if you're still fighting a fuel system issue at this point. Could be something weird like the FPCM dipping out.
    • Yeah in that case, pulling the dent out. Event a very slight dent can create a lot of work filler-wise and there is a strong chance the panel won't be the factory shape when you are done (as the dent will result in a new high point created somewhere, then everything is brought up to that new high point... but the panel shouldn't be that high if that makes sense).  So you've filled and primed the panel and it is flat, why would you go back and remove the primer and add more filler?
