got my cooler pipes today. they look mint, andrew did an awesome job. forgot a holesaw though. :)
got a bit of wiring and a bit of cutting to do, but its almost there. will post pics when its all back together.
Awesome! He does great work, I'd love to see some pics of it now
Have fun getting the holesaw through the inner guard, i gave up with mine and attacked it with a 1/8 drill then belted it out :(
haha. if i get frustrated and give up, i can get a pneumatic drill and a tungsten hole saw at my door within a couple hours for nothin.
that he does. but im gonna make you wait. :)
might swing by when its running tomorrow.
Edited by scandyflick
ladies and gentlemen, i have two words for you;
IT'S ALIVE!
started the 200 a little over 2 hours ago, tended to any leaks (there was 1), fitted the turbotech mbc (too lazy to wire in the ebc tonight), made sure the cooling system was going as it should, and put the front end back together. gonna have a shower and take it for a spin. :yes:
IT'S ALIVE!
started the 200 a little over 2 hours ago, tended to any leaks (there was 1), fitted the turbotech mbc (too lazy to wire in the ebc tonight), made sure the cooling system was going as it should, and put the front end back together. gonna have a shower and take it for a spin. :D
scratch that. problems already. hit a little over 1bar for a second on a test drive, pulled over straight away and readjusted the controller, problem is, now it isnt boosting over 0.5 bar no matter what i do, and it hits a wall at 5k rpm. :thanks:
    • Not sure the US can import anything other than the C34 Stagea's, but if you can and you need to to tow, DO NOT under any circumstances get an M35 Stagea. If it is just as a family car and your country/state allows it, absolutely and definitely get an M35 (3.5L if possible as it is effectively a 350Z) over a C34.
    • Punch your VIN (nm35-xxxxxx) into Amayama.com You can see everything there quite easily.
    • Thanks for that, I'll check it all out. I can always do the brakes last anyway if its a problem.  The 16's are super cool, if they do fit I'll cruise around with them for a bit.
    • Well, that's kinda the point. The calipers might interfere with the inside of the barrels 16" rims are only about 14" inside the barrels, which is ~350mm, and 334mm rotors only leave about 8mm outboard for the caliper before you get to 350, And.... that;s not gunna be enough. If the rims have a larger ID than that, you might sneak it in. I'd be putting a measuring stick inside the wheel and eyeballing the extra required for the caliper outboard of the rotor before committing to bolting it all on.
    • OK, so again it has been a bit of a break but it was around researching what had been done since I didn't have access to Neil's records and not everything is obvious without pulling stuff apart. Happily the guy who assembled the engine had kept reasonable records, so we now know the final spec is: Bottom end: Standard block and crank Ross 86.5mm forgies, 9:1 compression Spool forged rods Standard main bolts Oil pump Spool billet gears in standard housing Aeroflow extended and baffled sump Head Freshly rebuilt standard head with new 80lb valve springs Mild porting/port match Head oil feed restrictor VCT disabled Tighe 805C reground cams (255 duration, 8.93 lift)  Adjustable cam gears on inlet/exhaust Standard head bolts, gasket not confirmed but assumed MLS External 555cc Nismo injectors Z32 AFM Bosch 023 Intank fuel pump Garret 2871 (factory housings and manifold) Hypertune FFP plenum with standard throttle   Time to book in a trip to Unigroup
