i had the unfortunate experience of meeting the owner of the 3 week old ferrari. i spotted it parked near my mums place, so i took a pic, then after i parked i strolled over for a closer look. the owner came out, and i had a brief chat to him..... it seems he would need a car like this to get anyone to talk to him cos he is a total fkn asshat.
and to think here i was under the impression that the only ppl around that are unbelievibly rude and have a undeserved sense of entitlement are callers into BigPond wanting everything for nothing.
at least i kinda put him back in his box when his old man came out (i have known his dad for years cos i grew up a couple of houses away). he commented on his sons car, i said "yeah its awesome, pitty about the driver"
/rant
:rofl:
You obviously haven't seen my Hilux skids Dave :P
Actually, today I got bogged on a site in Hahndorf, so instead of trying to get out, did a bit of circle work for about 10 minutes. Best... day... ever... :thumbsup:
Oh and got out in the end too :)
turbo = $800, 480's = $400, retune = $5-600...
thats $2k that could be going towards my trip next year...
and ill probably need a new clutch on top of that, cant see my heavy duty organic coping with 240rwkw...
Edited by scandyflick
lol. i barely make money as it is...
slight correction, turbos only $600. dads throwing in $200. lol. thats bad. even my dad wants me to get a 71R.
Calling Chad, calling Chad......where are you??
Are you anywhere near my house tomorrow?
Need some welding advice bud (gates & RSJ's for a retaining wall).......would get my Dad who's a Boilermaker but he's fallen very ill unfortunately.
    • That sounds like an excellent idea. But total self-sufficiency means exactly that. You have no-one else to blame when your system faults out and you have no power for a week or two while it gets fixed. You'd have to go the whole hog and get a diesel genny and all the switchover gear, to get you through such times. And, despite the fact that over 20 years, my system has been pretty reliable**, I have seen so many inverter explosions (or less dramatic deaths), panel and roof JB fires, and so on, over that time, to know that the stuff is the same as any other bulk Chinese manufactured stuff. The failure rate is well above zero - both on the equipment and on behalf of the meth addled installation labour force. And then..... warranty and means of redress against the supplier you bought the gear from. Best I can tell is that only a handful of solar companies are still around within 5 years of starting their advertising pitch. They disappear and phoenix like crazy. So, as per 1st paragraph, I suspect the only way to is go balls deep and spend maybe 2-3 times as much as you might think, so that you have every base covered. Plus, know and understand your gear intimately, so you can diagnose problems, sort them out yourself, etc, etc. Plus, probably have to consider upgrading various parts as the years pass, to maintain compatibility with newer stuff, performance and reliability, etc, etc. Whereas, remaining attached to the grid has an ongoing cost that keeps going up even if you use bugger all power from it. But it does provide the fallback in case of the worst case with your own gear. You either pay up front or as you go, I suspect.
    • Add more solar panels to the array. Call the electricity company and tell them you're moving out... Live off grid electric wise
    • Hi Jasmine. How's the war going?
    • I'm extremely suspicious of the VPP stuff. Best I can tell, you surrender any and all control of your panels and battery to the VPP, because there's no way that anyone could write a sufficiently useful set of "rules" as to how much you would be willing to let out of your export meter at any given time. If one of your main interests is to have enough in your battery every evening to get you through the night without having to import, you could easily find yourself with nothing in your battery at the end of the day, or part way through the night, and then be paying import pricing instead of paying nothing. I cannot see how this cannot come to pass.
    • majority aftermarket is an10 yes, but majority of OEM is An12 r35 OEM cooler lines at close to an 12, the hard line that car uses is almost 20mm  Porsche OEM is also AN12   i figure, if our power levels are close to 1000hp, then AN12 should be a must if many OEM standard power vehicles use AN12
