What's the max wheels that'd fit under R32 GTR guards? I've seen 18x10+12 and they're still inside the guards. Anyone know of anyone running 18x10.5?
dont know how wide my rims are but i got 275x35 tyres on 18s. id say they are as big as you can go without rubbing as there's very little room on full lock
must have a look 1 day how wide them rims are.
Edited by Inline 6
Who here has the right equipment (timing light) to check the timing on an RB25DET motor? (I know a normal timing light from the auto shops don't work with coil packs). Would like to check the timing on both my rides this weekend.
:D
:D
All you do is take the no.1 coil pack out take the boot off and put a regular spark plug leed between the coil pack and the spark plug. Then you hook up the timing light to the leed as per normal
Yeah ... there's always that. But I don't even have a regular lead :D
I have 18x10 +20 rims on my R32 GTR with 275/35/18 tyres and had to get the guards rolled to fit the tyres. These rims came with the car but I personally wouldn't go wider than 9.5" if I was buying rims for the car. My rims sit inside the guards at the top but not at the bottom. I wouldn't even try for 10.5".
http://www.news.com.au/adelaidenow/story/0...5006301,00.html
that happened like 50m from my house and it looks like the car they used was my old r33 that i sold to a guy that lives locally
hope its not my old car :rofl:
Omg it was a 1996 Nissan Skyline! It was horrible! Wont somebody think of the children!!!!!!!!!!
hey daniel would you like to upgrade your current mobile phone plan?
just thought id join in
its funny cause i've been pestered by telstra lately about that.
and yes i did mean coilpacks, been getting an intermittent ignition fault code and its been narrowed down to the coils.
anywho...
have just put up a couple more photos, nothing special again and listed a couple of small things in my garage.
it was a s2 r33 in dark silver with 34 gtr rims onit
was on the news a little while ago.
and after tonights activities, matty has me seriously considering getting a rig of my own :rofl:
Although that happens after everytime we go out in it lol.
Anyone wanna buy a BA falcon? lol. Its got rims and exhaust yo!
    • Actually, that's not entirely true. It's also the same motor in the 1st gen Nissan Cube but they're rare as hen's teeth.
    • Yeah it is always worth testing and balancing actuators out of the box, just set the pressure regulator on a compressor very low (eg 5 psi) and increase it slowly to see when they both move.....unfortunately while you may be able to adjust the length of the actuator rod to minimise any difference, the actual pressure they move from is not adjustable so you need a well matched pair. And yes, the VCAM is probably contributing; the earlier in the rev range they come on boost and the slower the revs build (I think your demo was in 5th), the more you notice it.  Driving at WOT through 1st, 2nd, 3rd etc you will probably never hear it as any shuffling starts and is over super quickly
    • oh they were with that motor, you need to remove the engine to change the spark plugs (don't have to, but it does make it easier)
    • I certainly fall into the annoyed camp, but glad to hear that if it's happening at low boost then I'm not likely going to blow a turbo and end up with metal shards in my oil. Just feels like it prevents me from really driving it without hesitation and "peak" performance. Wonder if it's the VCAM, it did an impressive job of shifting the torque curve and faster spool, but maybe now it's "too fast" and there's too much air for how open the throttle is.  Based on some other threads, will also do some reading on synchronizing the actuators. They are the default actuators that come on the Garrett's and I would think they would be set the same coming from the factory, but if the turbos don't actually work exactly the same way at the same time as previously mentioned, it would be worth making sure the actuators are actuating together properly
    • I went down this rabbit hole before, ended up sourcing a motor from the UK (I'm in Japan) which also didn't function correctly. With the original motor, I disassembled it and reassembled it and it works somewhat, sometimes. What I could deduce from all my screwing around is that there is calibration of the gears on the inside of the motor and two ramps on the main gear which activate switches that operate the motor and move the sunroof either to retract into the roof or tilt. Where I got stuck was that, it seemed in my case that one or both of the switches that are activated by the ramp on the gear did not always activate and thus the motor did not move, causing it to sometimes not retract or tilt (apologies, I've forgotten which way it didn't work.).  Of course this part is discontinued at Nissan now, it's the same part in the S15 but no other models. I also contacted the manufacturer of the component for schematics - forgot the name, they're based in Gifu - but they declined to share the information due to being bound by an NDA, sadly. Looking through my pictures now, it seems I last had a crack at this in 2022. See, I so kindly wrote "open" and "close" next to the switches. If you figure it out, please do tell me. Those little switches, with the red buttons may need to be replaced.
