do you want just the stand alone screen? flip out or a double din fixed unit?
Really all depends on cost and what you can get. Ideally i want to get rid of my cd/dvd headunit, and 3 gauge din holder and put a 7" touch screen in there, so it will need vga input with a usb output - for the touchscreen functionality. It will then be connected up to a craptop (laptop that is well, crap) that i got from work for free, which will be connected to my haltech ecu so i can get read outs - woo rice, and play music, gps, etc etc of a carpc.
I have been looking at these lilliput screens. I am looking to be setting my carpc and car interior retrim up around the end of the year, performance mods first - which is almost done, around september/october time.
someone on NS.COM said pooraka petrol station has 100RON with up to 10% ethanol!
new replacement for e85?
probably not... not enough % ethanol to make a real differance so you wont see/get any of the advantages of ethanol... oh, and only 100 ron
why is there no f ing cheerleaders at the footy? as if it wasnt gay enough already.
got forced to attend and didnt even have anything to watch all game wtf
don't you go to the footy to watch it? Well, you could have gone downstairs and gotten plastered in the drinking section.
ofcourse i dont go to watch it, got dragged there by my boss who had season tickets n no 1 to take. even she is regretting buying em.
crows won something like 120 to 15 and i heard carn the crows about a million times
heaps weird theres people there that pay the money for a ticket n then just watch it on the tv at the pub there, why not just do it at a bar nearby for nothing
Edited by Inline 6
ah yeah sorry Jack. I am after a stand-alone screen that I can have a fibreglass shroud built to custom mount it on a dash. Planning on plugging an EeeePC/Acer Aspire One into it to run full time consult display tools from ODBII. Resolution needs to be around 1024x600 or so, and needs to have a VGA conector (and USB connector to run the touch screen obviously).
Are you planing on mounting in where the 3 gauge holder is ontop of the dash in the 34? or do you have the flip out factory screen ontop of the dash and would like to put a fixed touch screen in there insted?
As Abe sugested before the lilliput screens are very popular with guys doing what you two are.
No probs with getting rid of the CD and 3 gauge holder in the dash,did you want to keep the pocket underneath it or get rid of that too? As i said in the other quote the lilliput screens are very popular for this kind of thing and i would highly recomend them.
Ill see what else i can find for you guys and get back to you both via PM.
Pocket underneath? I have my climate control up top, jvc dvd headunit, then my 3 gauge holder - with 1 gauge in it, right below that is the ashtray etc etc. I am wanting to maybe get rid of jvc headunit and 3 gauge holder, as ill have readouts on the screen, and the carpc for music, etc, and keep the climate control for well, aircon and heating i guess.
i wouldnt mind a 4x4, like a jacked up hilux or something but moving out of home comes first atm
also thinking about getting rid of the 33 already as im growing bord with it so i could get a decent 4x4 maybe or maybe just a normal car.
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
    • For race cars, this is one part where I find having the roll cage bar having gone through a hole in the floor better than the build it up on a ledge inside... The Merc I help on, the main hoop ends are marked on the car, and the jack is marked... Jack goes under a few inches and lifts one whole side of the car up... Removes that fight for long slim jacks for race car duties!   My biggest issue for the daily drivers I work on, is my jacks don't go high enough. The jacks start out on a few blocks, jack it up, then start a second jack under it on more blocks, and then I can get an axle stand under it. My axle stands are presently in use, and are nearly fully extended. The car is sitting with barely more than a cm of clearance to get the wheel off the studs! Sarah's Kluger is the same, as it has an ungodly amount of droop available in the suspension and a distinct lack of good jacking points!
    • Happy? Yep, my to do list is getting shorter and shorter. Either this light approaching is the end of the tunnel, or I'm about to be hit by a train... Ha ha ha   Also, Duncan isn't that far out of town that you need to make a multi day drive out of it. 😛
    • Sorry I meant that we are building the EH for a client.
    • LOL, when one "money pit" is never enough Noice, and excellent work mate
