got to drive a turbo car on the weekend for the first time..rb25...straight pipes..rrreally need to get on the turbo side of life.. big change going from a 100kw 30, to a 210kw 25..
not questioning it, just you have been talking about super chargers and turbo's lately.... thought you might have chucked something on there. At the end of the day it's horses for courses.... how fast can one go with all the nazi government shit...?
