quick question, what are (if any) the differences between a rb25det found in an R33, and an rb25det neo from an R34?
i heard that the neo is more fuel efficient, but is that it?
the coilpacks are different and the top internals are different aswell, um vct aswell
and the neo overall is a stronger engine......totally different ecu to the r33 rb25det too
