QUOTE (whatsisname @ 30 Jul 2009, 07:16 PM)
Not sure where the RB25DET engine torque figure listed above came from, but it's actually quoted by Nissan as 30.0kgm at 4800rpm - just under 295Nm.
The UK skyline forum and another source..... Nissan
seat of the pants you can feel a huge difference in mid range from S1 R34 and S2 models in the same state of tune , even more so when you add a 270.00 part it improves the car dramatically in the low to mid range punch to make it soooo much better to drive daily
Troy, either we have a simple case of miscommunication, or you've plucked that Nissan claim out of your backside mate. Are we talking about the R33 Series 2 RB25DET producing 319Nm peak torque? If we are, then I will happily stake large sums of money on it that Nissan claim 30.0kgm (just under 295Nm) at 4800rpm for the GTS25t RB25DET engine - the factory Nissan Japan 1997-1998 R33 Skyline GT-R and Skyline model range glossy specifications, options, and accessories catalogues on my desk at work tell me so :)
^^ But Nick, they do expect it to be a girly hairdresser's car - and it delivers :)
Muhahahahahahahahahahaha
j/k mate .... she is a good car :down:
whats going on with this new car of yours mate? been delayed again?
Where do you guys go for cheap (bargain) tyres?
At the moment I'm considering having a pair of Federal 595 SS sent from forum trader Access....
I just got some Federals from Option1Garage. Can't remember what type they are KU71 or something. I was trying to get their street legal semi slick but they didn't have any in stock. Cost me about $350 del for two new tires. Pretty good in my opinion
yeah Nick they replaced the vehicle speed sensors, but it didn't fix the problem - despite the ECU error code being 'vehicle speed sensors'. They are having another look at it Monday.
I am in no hurry to get it - in fact the longer it takes and the more things they fix/replace before I get it, the better for me, and the more time it gives me to sell my car (a guy who is interested is coming to look at it tomorrow). I was dreeading the thought of having 3 cars and only 2 garage spots. Meant I was going to have to put the new one out under the verandah where the R34 lived for the first 6 months of its time in Aus. Not easy then to just take either car to work in for the day depending on my fancy :)
Bah I like missionary though... the giving side of it... not the receiving. Because I'm so generous and all. :down:
Any way to scam the scammer and run off with $7k or so? :)
How about set up a fake Paypal account, get him to transfer the money into that one, once it has cleared, transfer it into your proper paypal account, then into your bank account. Or just tell him to get a bank to write out a personal cheque and send it to you.
What a shit day!
I woke up with a headache. Did some housework. Watched the Crows lose after getting reamed by the umpires in the first half. Decide to go and wash my car and get done by a red light/speed camera on the way to the car wash. I was doing exactly 80kmph in an 80 zone and was well into the intersection before the light went red. F**king $300 odd dollar car wash! How can you contest the bloody tickets without risking an even greater fine?
I should have stayed in bed.
What a shit day!
I thought the same thing this morning when i got up for work, but it was alright, i played UT3 all day while drinking Ice Coffee.
215/40 on the front!
yeah but i'd have to run 235's front and rear for the 4WD so the tyres are no good and i wouldn't fit 18x9 +20 in my guards with 235's on them, as im running 18x9 +30 atm.
    • Not really, but the heater box is pretty simple mechanically....if the door is one way the air bypasses the heater core and if it is the other way it goes through it for warm air.  If you are sure the actuator you moved manually is for the heater mix (there would also be one for output air direction) then I'd take the heater box out and see what is happening (you'll have to regass and re-coolant the systems afterwards) BTW pp724 onwards from the GTR workshop manual cover the system in good detail, it is probably worth checking. I think the IAT sensor might be a problem electrically for getting cold (if you got 24 error code not -24 it thinks the incoming air is -50c) and it covers how to test the sensor (although most likely it is either not plugged in or a wire is damaged)
    • Use the GKTech subframe bush and bring your subframe 10mm closer to the chassis. You'll need to fix an exhaust hanger to suit. One of the best mods I've done.
    • You'd really have to pull it apart further to know, it least you can be confident that the one heading to the back is not connected any more. There was once a ground on the shifter seal mount too, your head unit issue could be that simple
    • Perfect, I'll get to it this winter then at the same time as I weld on my anti squat kit.
    • Alright so my 32 only has one temperature no matter what degree you set it to. I’ve tried disconnecting the servo motor arm and moving it either direction and got no change. I’ve fixed the leak in my AC and re charged it and with it on and clutch engaged it still blows hot even though the low pressure pipe going to the firewall is ice cold. Both heater core hoses are hot while running as well. Diagnostic code showed 24 for intake air temperature sensor. Anybody got any ideas?
