gonna join matty and pete on their next 4wd day eh? :P
nah, seriously though, good luck getting it through, should be a first time easy.
also, i love 31 club. so easy to break people there. turned someones thread into a thread about alpacas. he got emo. i lol'd.
Edited by scandyflick
linksy?
anyone know how to delete/cancel an ebay auction? listed my injectors, sold them to someone on the 31club, no longer need the listing...
... never mind, figured it out.
Like my new purchase, it HUGE.
http://www.acer.com.au/acer/product.do;jse...;CRC=1864640160
25.8x18x2.54 cm and just to give you an idea how big that is;
I got the EEE 901. Upgraded it to a 2gig ram memory stick, removed the slow 8gb secondard ssd and replaced it with an uber fast 32gb ssd. chucked an sdhc class 6, 16gb SD card in the card reader. Wireless bluetooth mouse, wireless bluetooth via my sony ericsson k850i to the net, usb DVT-B decoder... bloody love it
am running fedora linux on the 4gb ssd, windows xp home on the 32gb ssd and i have the 16gb card for media storage... 48 gigs of media avail to windows
not bad considering its got no moving parts. being turned on in a skyline aint gonna kill it heh
the only thing I wish I had was a touchscreen. would be uber. you can get kits but im not quite prepared to disassemble the eee...
little computers rule
-D
this is the 10.1 inch aspire one there is a 8.9 inch version but after looking at other 8.9 inch net books they are too small for me (as it is it's taking ages to type even with this one cos of my fat fingers).
This is the D250 version which i have had the RAM upgraded to 2Gb, it has a 160Gb hard drive and a 1.6GHz processor. all the small net books run the same intel N270 processor, the reason in when for the D250 over the D150 is most of the specs are higher, the RAM is upgradable (standard they came with 1Gb) and they have bluetooth standard as well and it's <$100 between the two anyway. i paid $668 with a LITEON duel layer external DVD burner included.
i will get a 16Gb SD card for it and put all most of my stuff on that, that'll be next week though asi ahve just bought a 9 cell battery for it because the standard 3 cell one is lucky to last 3 hours.
I wanted something small for uni as well as Data logging at the track and eventually i'll run some lipstick cameras to it as well.
Edited by D_Stirls
man... i hate when books i enjoy (and books that have good potential for the big screen) always turn into garbage movies.
sure, as a rule, movies are never as good, someone elses interpretation of the story is never as good as youre own.
but deleting entire characters and subplots then turning the finale completely on its head... whats with that?
    • For once a good news  It needed to be adjusted by that one nut and it is ok  At least something was easy But thank you very much for help. But a small issue is now(gearbox) that when the car is stationary you can hear "clinking" from gearbox so some of the bearing is 100% not that happy... It goes away once you push clutch so it is 100% gearbox. Just if you know...what that bearing could be? It sounding like "spun bearing" but it is louder.
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
