They will 15x6.5 so are the wrong size since he is looking for 14's
Adrian of you are looking for 15's then i ahve a set of light weight 5 spoke 15's that you can have for $300.
hey do they have tyres? and whats the sizes?
yep Breaking Bad and Dexter are 2 of my current faves ..... along with Weeds and True Blood! Can't wait for Californication, Chuck and Dollhouse to start back up soon too.
season 4 ep 1 of dexter has me hanging on the edge of my seat !
They do but only 2 have tread and the other 2 are hard because they are fairly old. same size as the factory rims 15 x 6.5. the tyres are either 195's or 205's
Edited by D_Stirls
I've seen all the other shows you've listed but never heard of Chuck. ATM watching weeds, True Blood and Entourage as they are released each week. s04e01 of Dexter was good but a little predictable.
I'm really hanging out for the final season of Lost. I just re-watched all 5 seasons to remind myself of the storyline and all the plot twists.
hey didnt really know where to put this but does anyone know why i can only send 1 private message then if i try to send another it says there is an error and that i have to wait till a certin time and its like 8 hours away or something like that. is it coz i havnt made many posts or what ?
Edited by -pumba-
^^^ no it is flood control to stop the spammers who were consistently spamming SAU for a while there. I believe if you donate to SAU (go to 'purchase paid subscriptions' (or something like that) in your user cp) it is lessened. Even I have a limit of PMs I can send per minute these days - it used to be unlimited for me :)
I paid the deposit on my new car today :) .... and NO, none of you have seen it .... the 2 I were looking at both got sold on me :ninja:
I hope the mechanical check holds up tomorrow - but it darn well should on a car with only 27,000km on it!
Got any pics Dale? Looking for a more "fitted" rim for my 31, has some sort of 4 stud Nissan rims on it with a very high positive offset.
%*&^! beautiful
Presumably one of the first in Aus too hey.
that thing will grow in value down the track!
WANT! however the bank probably wont agree with me. nor the missus... blah
some lucky chump will land it
Reckon I might have found the reason why my Stagea is running so poorly.
The FPR hits nearly 60psi on start up/warmup and makes a slight whinning noise, then drops to barely 30psi after 10 seconds or so and the whining noise goes away!
I'm swapping the FPR tonight. If the car runs better, then I'll know its the FPR.
wasnt that the malpassi one ruby ? Ive had them die a few times on the RB30 and now keep a spare wreckers one in my parts box..lol
    • Then, shorten them by 1cm, drop the car back down and have a visual look (or even better, use a spirit level across the wheel to see if you have less camber than before. You still want something like 1.5 for road use. Alternatively, if you have adjustable rear ride height (I assume you do if you have extreme camber wear), raise the suspension back to standard height until you can get it all aligned properly. Finally, keep in mind that wear on the inside of the tyre can be for incorrect toe, not just camber
    • I know I have to get a wheel alignment but until then I just need to bring the rear tyres in a bit they're wearing to the belt on the inside and brand new on the outside edge. I did shorten the arms a bit but got it wrong now after a few klms the Slip and VDC lights come on. I'd just like to get it to a point where I can drive for another week or two before getting an alignment. I've had to pay a lot of other stuff recently so doing it myself is my only option
    • You just need a wheel alignment after, so just set them to the same as current and drive to the shop. As there are 2 upper links it may also be worth adding adjustable upper front links at the same time; these reduce bump steer when you move the camber (note that setting those correctly takes a lot longer as you have to recheck the camber at each length of the toe arm, through a range of movement, so you could just ignore that unless the handling becomes unpredictable)
    • I got adjustable after market rear camber arm to replace the stock one's because got sick of having to buy new rear tyres every few months. Can anyone please let me know what the best adjustment length would be. I don't have the old ones anymore to get measurements. I'm guessing the stock measurement minus a few mm would do it. Please any help on replacing them would be fantastic I've watched the YouTube clips but no-one talks about how long to set the camber arm to.
    • Heh. I copied the link to the video direct, instead of the thread I mentioned. But the video is the main value content anyway. Otherwise, yes, in Europe, surely you'd be expected to buy local. Being whichever flavour of Michelin, Continental or Pirelli suits your usage model.
