yeh thats what im thinking matty..
also, just picked up my rolla from workshop to have a $710 bill..
what was done?
diff locked, vlturbo pump supplied by workshop)(its external so 5min job), indicator switch ($30), oil filter ($15), tighten back brakes (handbrake still doesnt lock), compression test..
7.5hrs labour to do that?? $500 just for labor? is this correct or should i not go there again?
If it was 7.5 hrs then $500 is a good price. I pay around the $85+gst mark per hour
I have nfi about mechanics so I dont know about the time, but given the list of stuff u got done, it wouldnt surprise me if that were about right
-D
i was gonna say, whats coming next :)
It'll be another 180 to do that 25 conversion on. with all the parts that would be coming out to do the conversion i would be basically parting out the whole car so I'll sell the current 180 and start again with another stocker.
for anyone thats keen, a few of us are going to the Lakes hotel to watch the game tonight.
141 Brebner Drv
West Lakes SA 5021
if you need my number for anything, shoot me a pm. Myself and Adrian will be there at around 6ish, game starts at 6:30
xoxo
Should be a mint game, Carn the Crows :)
Got my coilovers in, fully wound down it sits lower, but not as low as I would like but ohwell,
I got something coming that will be my fitment pig :) aha
Edited by Weezy
shouldve got a set that are base height adjustable. run as low as you want without having a crazy uncaptive spring.
but yeah, run it a little high, bout the height of heslo's car would be ideal, low cars sucks.
    • We have a huge update coming in the next few months, version 5 of Invision will be released. I'm holding off any changes until after this change as I'm not sure what features will be removed or introduced.
    • Yeah, plenty of air flow, there is a dedicated path that feeds the air in to the OEM intake tube behind the bumper As for a "tangible effect", maybe, but getting the pod/intake air out of the hot engine bay is worth it psychologically to me, even if it gives no performance difference, so the tangible effect in my Lizard brain saysss yessss  In the end, to me a tangible effect isn't always about performance, sometimes it a sound or a look, or even a...... feeling  Ooga-Chaka Ooga-Ooga Ooga-Chaka Ooga-Ooga Ooga-Chaka Ooga-Ooga Ooga-Chaka Ooga-Ooga
    • yeah first and reverse is where you will find clutch release issues (whether hydraulic or mechanical) because the difference in revs required is the highest there; particularly changing down from 2nd to 1st when still moving. To be clearer though, it is possible that the clutch release bearing is the wrong height. This is less likely than a hydraulic issue but it is not unheard of when you are mixing and matching
    • Quite right, if you make it to that pension you deserve every cent
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
