diddnt want to put this in for sale thread as im just enquiring on interest at this stage.
but looking to sell my 32gtr .. most of you know the vast list of bolt ons. all modifications are approximatly 3000 kms old. ive speant nearly 20,000 on this thing in nearly parts alone.
remember its a 1993 with revised r33gtr crank (less oil control issues) with 101xxx kms and books
asking price is 28000. yes this may seem high but im not ready to sell unless the price is right at this stage
dyno sheets show 305 awkw and 332 rwkw
does anyone no when daylight savings start???
End of Oct i think...or this may help
*EDIT* Just read the link i posted, First Sunday of October, so this year it will be 04-10-09. Also Windows 7 is telling me Sunday, 4th October @ 2:00am, the clock is set forward 1 hour.
Edited by Aberax
he wont do it, hes just confused :P wait til he finds the right stroker kit or 30 bottom end and hell be set
well ur plan to lose the 34 failed miserably ;) the lure of the skyline. i shall call mine "venom" cause once the sybiote takes hold it cannot be seperated.
:P
+1
Looks a Really Clean GTR
matty, shoulda got the -200's, -72 just doesnt fit well enough. :P
ps, after much laziness, oil cooler is almost ready, not where i was originally gonna put it though, its now sitting in front of the radiator, just need to buy 1 more 90deg fitting and im done...
... also fit my new bootlid, but it doesnt close properly, some fine tuning is required me thinks.
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
    • Thanks @jtha7 I will have a look around tomorrow but it is a prick of a spot. These are some photos i tried taking
    • I take it that the knock retard is from bearings tapping a little tune? Thicker oil is a fragile bandaid. You need a much bigger oil cooler and probably the bigger pump being discussed.
    • Hi @Chupapy i had several leaks from coolant pipes being corroded, i also had one leak on back of the head onto transmission. For me that leak was from the turbo water line. Follow the line to the back of the head The hose and metal pipe had perished these are the best pics I took of it at the time
