nah no bogan, im not into incest
i do like aussie muscle tho.. xu1/slr5000 toranas, chargers, xb/xc fords...never got into monaros tho... i also like american muscle (57' thunderbirds, 67 camaros, corvettes, pontiacs firebird & fieros etc)
they're the exception to the rule sadly, most australian (and american) cars are utter garbage. much to my chagrin.
-D
Edit - and while I detest 4wd's, f150s/250's are quite ruggedly over-engineered
I probably should of used italics. Each to their own, I do like some of the aussie and yank classics too
Anyone know why i would have shocking fuel economy? Getting roughly 250-300ks a tank.
That's shocking :P , i used to get about that with my car, not sure what its gonna be now after the retune etc.
yup new O2 sensor time, I replaced mine recently (4wire wired up to 3wire connection)
I love the Corvette Stingray, 67' is a classic but Id love a 77'. With a twin turbo 6.0litre V8.
Also love the TA-22 77' Celica, with a RB25det she'd be awesome
As for 4wd's - I hate the size of the things, but recently we got a make-believe 4wd, the Ford Escape 02'.
not a bad car whatsoever, very roomy inside (enough for 4x 200cm tall adults + luggage comfortably), but not that huge on the road. easy to handle.
very happy with the purchase at $6500 incl. tyres, airfare and petrol melb-adl. spending $500 on it atm thru Boostworx and its in top notch condition.
also dropping in the injectors, setting up the ecu and tune, on the 8th. cant wait. Boostworx of course
:P
Pulled the engine cover off the RS250 race bike today, found some bits floating about in there that shouldn't be! One part was a dowel pin or piston pin by the looks of it! :P The other part looks like a bit of the casing damaged by the pin. I reckon someone has intentionally dropped this pin into the oil cap hole to f**k the engine up. A bit pissed off as it could have been dangerous as it jammed up at about 170kph at the track at the time I noticed the noise. Lucky its only isolated to the clutch basket and kickstart gearing, and not the crank or barrels. Anyhow, now I gotta rip the engine down to make sure its all okay. :P
That sucks Rubes.
We sent an engine off to get rebuilt once, when we got it back they told us that they found a tappet in the sump :P
Yeah, I figure if I'm ripping the engine down for look for other problems, I might as well rebuild with new pistons etc, and AF1 heads. The engine is barely 500kms from its last rebuild, but its compromised now. And at 9,000rpm and 200kph on track, I can't afford a compromised engine. I'm also shopping for a spare engine too, just in case it pops in the middle of the season.
My racing budget is already hit hard now, and I haven't even started the season yet. :P
250-300 kms to the tank? ouch, i'd hate to see your fuel bill.
Managed to crack out a solid 600km this weekend on one tank in the 31 with 290,500 kms on the dash. Mind you, that was highway driving to Victoria.
that was slipstreaming me jakey
and nice dirt turbo too at the first piss stop :thumbsup:
true jake, very true. a fridge like mine would be gangster as in your mo-bile
oh, and as for our discussion last nite on the maccas run
http://www.skylinesaustralia.com/forums/Sa...-1-t285710.html
does anyone know what would cause a battery to spark and go all smokey (on the negitive side) when trying to start a car?
happened on my drift car today, gonna get a new battery but not keen on it happening again.
    • So either way it is gearbox out and look what is wrong?  I know about the input shaft bearing. Even before swap/new clutch the it sounded exactly like this: So is that inout shaft bearing or the other was installed backwards?  And can some please tell me the part number for that input shaft bearing? The gearbox is small box from R34 N/A and number is FS5W71C. Thank you
    • I am yet to see anyone ever regret a quaife or helical. ...other than drifting/skidpan duties. I kind of want to upgrade my factory helical with a Quaife (but really it's not ultimately that different, and is a MASSIVE UNDERTAKING), that's how good the hype is about them, that I want to try them 'just to see'
    • D2 and Ksport are essentially the same thing and basically just generic Taiwanese manufacture. Better than ChinaBay crap, but... not top shelf. Öhlins have got to be some of the best dampers around, so likely to be a good option. It's going to get to the point though where I suggest you buy from Oz. We have at least 2x excellent options here. If I were you though, I'd be talking to KW about doing something for the R33. There's bugger all difference between that and the 32. In GTR land, anyway.
    • KW only offers a set for the R32 GTR. Popular options are D2 racing, Ksport or Öhlins. I have a D2 Racing coilover set, though I don't know for sure which one.
    • Well, the good news is you have more than one very good option for new coilovers in and around your country. Worth the drive over to KW to talk about GTR stuff.
