If you're a trader, then Nisskid is Bill Gates :)
there's a difference between trading a lot of items and being a business. maybe we should call every person who wrecks a car a trader due to the amount of stuff they sell.
i dont know what mitch was called out for, but id be interested in knowing what it was.
because i was saying "ill have this arriving next week" n shit like that
arriving = my spare car thats sitting in my cousins front yard in vic...
nearly got a suspected defect fine for my non existint bov. cop keep asking me to rev it, so i revd it a lil then he like nah harder. went on for a couple of minutes, while i just kept telling him have a look if you dont believe me. was preparing a speech to try n explain why it makes a noise anyway when the cop next to him spoke over him and said let him go :) good to see they keep 1 around that knows there cars.
the big problem is they hate to be outsmarted, if they get backed into a corner where there clearly isnt one they will just get more angry and want to defect u more, so u gotta be careful about it lol
i just showed them the standard recirc valve and said thats what the aftermarket stuff replaces.
