well, the unnamed speed shop still doesnt have my part in.
lol they promised you 3 spoon engines?
Johnny Tran: [interrogating Ted about his missing engines] What are feeling, Lance... 40 weight? 50 weight?
Lance Nguyen: 40 Weight sounds nice...
I thought they were NEESON SR20's?
needed help asap. Anyone know how to replace a castor rod in a 32?
Easiest job in the world if it is like the R34 (and a castor rod is the same as a Z bar).... 2 nuts from underneath near the wheel hub, and a double ended bolt/nut through the bush at the front and you are done. Just jack up the car, rip off the wheel and you will see how easy it is.
yep, its not too hard, and everything is easy to reach, which is a bonus :cool:
Dang, you must be pissed by now Dave .... but lesson learnt not to buy stuff for a Jap car from a V8 bogan speed shop .... especially when so many Jap traders have bolt-on kits ready to go ....
In lighter news, finally found time to fit my carbon fibre engine cover and intake pipe yesterday .... and half way through fitting them my new axle-back exhaust rocked up, so I fitted that as well .... mmmm Titanium tips :cool: Has a very healthy rumble now too :down::/:(
nice Andrew. I do love V35's.
now for something different.
eyes lit i want short breaths i found dark eyelids nice breasts like summer into rough hands
oh, youll love the bit about me having to remake some of my lines.
meh, the dude i ended up with at the end knew his shit, the morons i had leading up to were pretty useless.
f**k i hate that game. got 1 bloke that follows me around everywhere, has been there for the 2 mistakes ive made since i learnt that game a couple weeks back, rants and raves about them constantly. people wonder why i have semi violent tendencies.
    • neither stumble or cut really seem to be an appropriate term....hard to explain its like a rev limiter but at 4k, but it violently shakes engine and entire vehicle as the rpms will not rise over 4k, even with slow acceleration. as soon as it hits 4k, it sounds like entire spark is lost entirely. plugs were 1.1 which I used as such, but later put in new plugs gapped down to .8 changed back after issue arose when I replaced the coils, still does it with either plug gap...damn and it was all running so good.
    • Oh how times have changed! I actually lean it out relative to my water/methanol injector duty cycle. The methanol adds a lot of fueling and you can then lean it out even more due to reduced knock.
    • Yeah my thoughts are the same, a well thought out WMI setup, would be slightly ahead of just straight E85 and you're also chemically intercooling the charged air, dropping it even further. This is why you need to add so much more fuel as soon as you spray. I remember someone taking me through their set up before (Dennis, has a R33, lives around Cabramatta - no idea if he's still around on this forum). He would target AFR 10:1 on 98, then as WMI ramped on, AFR would lean back up to 11:1. Amazingly, he did this all through his PowerFC, a relay to cut power to his EBC solenoid if there was not enough line pressure on his WMI kit. And of course, if there wasn't any boost made above gate pressure, you wouldn't be accessing the load cells with heaps of timing for WMI. One downside to that rudimentary setup, once the WMI came on, the EBC would unleash the dragon, and of course all the timing. Tyres would fry lol.
    • Shimmed or shimless, still solid, no hydraulic pump up stuff.
    • They have said food will be limited. Mainly meat pies and sausage rolls from memory. But they have a coffee van!
